GerryS wrote:Any jeep liberty (2005 vintage) owners out there? I need to know the height of the receiver measured from the ground to the bottom edge go the receiver. I've got a new tow vehicle and I need to figure out how much drop I need in I my new drawbar....
GerryS wrote:I had the same problem with not spare...I never added the extension...but a couple time I did have to remove the tire :/. 14 sounds right. Now to beasure the f150 probably going to need a 4 inch drop from the way it looks....that thing is tall!
Dale M. wrote:Just measure bottom of new TV receiver to ground... Set trailer level.... Put the ball in trailer socket, measure from base of ball to ground.... Subtract smaller from larger to get difference, go to Auto Parts or RV dealer and get draw bar with the same dimension from bottom of draw bar (at receiver) to top of where ball mounts........
Also be aware some new vehicles (maybe only those with large payload capacity) now have 3 inch receiver (or maybe its 2-1/2 inch) ..... You may need adapter to use 2 inch draw bar....
Dale
