Mobile Fit Club Build - Tommy2tone_1999
Re: Mobile Fit Club Build - Tommy2tone_1999
Postby hmikey » Wed Jan 22, 2014 9:21 am
Hi: Great looking start. In the photo, is your floor frame already bolted down? More important, did you ever discover what the wedge shaped parts were? Mike
hmikey
Postby Tommy2tone_1999 » Sat Feb 01, 2014 6:55 pm
Never did Mike. I finally got more CPES in today. Saw dust flying recommencing
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Feb 02, 2014 2:44 pm
I went to finish sanding the remainder of the primer on the pre-primed plywood for my floor so that I could begon applying the CPES. I found that the top layer had begun to delaminate with the muggy weather over the last couple days. Should I continue with this plywood or get more?
Tommy2tone_1999
Postby Tommy2tone_1999 » Fri Feb 07, 2014 10:34 pm
I decided to just replace the boards since I was still at a beginning stage. I bought 2 4x8 sheets of cabinet grade plywood and had them cut at the store to 5'. Here I am applying 3 coats of CPES to seal them.
Last edited by Tommy2tone_1999 on Mon Dec 08, 2014 12:33 pm, edited 1 time in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Feb 16, 2014 6:13 pm
Holes cut in the floor for the storage compartments.
Tommy2tone_1999
Postby absolutsnwbrdr » Fri Feb 21, 2014 3:25 pm
Tommy2tone_1999 wrote:So there's gonna be an X3?
Hey Tommy, you already stumbled across my new build, but yup, the X-3 is underway!
I was just looking at your pictures, and those two galvanized "wedge" pieces that you were concerned about are actually the fender mounts for the "squarish" fenders that come with all the other trailer kits. It seems that all the Changzhou Nanxiashu trailer kits (both Harbor Freight & Northern Tool trailer kits) share a lot of the same hardware including the lighting. If I recall, those galvanized brackets are in the lighting box, so they must automatically get supplied with all trailer kits, regardless of whether or not they get used.
Nice start by the way! Sucks about the plywood delaminating. Cant wait for more pics!
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Tommy2tone_1999 » Mon Feb 24, 2014 11:40 pm
Just installed the staibilzer jacks. Had to make cross braces from some angles to mount them.
Last edited by Tommy2tone_1999 on Mon Apr 06, 2015 3:42 pm, edited 2 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Mar 16, 2014 2:45 pm
Fitting the floor storage compartments.
Last edited by Tommy2tone_1999 on Mon Apr 06, 2015 3:43 pm, edited 2 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Mar 16, 2014 2:47 pm
The edges of the floor storage compartments and the pocket screw holes sealed with calking
Last edited by Tommy2tone_1999 on Mon Apr 06, 2015 3:44 pm, edited 1 time in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Mar 16, 2014 2:49 pm
Floor and storage compartment boxes installed to the floor frame.
Last edited by Tommy2tone_1999 on Mon Apr 06, 2015 3:44 pm, edited 2 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Mar 16, 2014 2:50 pm
Applying Zinsser oil-based primer to seal the plywood before painting on the roofing asphalt. This will prevent any possible delamination from the asphalt compound.
Last edited by Tommy2tone_1999 on Mon Apr 06, 2015 3:45 pm, edited 2 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Mar 16, 2014 2:51 pm
The floor turned upside-down, and 3 coats of Zinsser oil-based primer to seal the plywood
Last edited by Tommy2tone_1999 on Mon Apr 06, 2015 3:46 pm, edited 2 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Sun Mar 30, 2014 4:42 pm
Roofing Asphalt Compound applied to bottom side of floor for waterproofing.
Using these fanged washers to allow me to tighten the carriage bolts that secure the floor to the trailer frame.
Carriage bolt and fanged washer.
Driving the fanged washer into the plywood floor.
The hole in the floor was recessed to allow the carriage bolt to sink below the level of the floor. I will use the stop nuts to tighten it down. Later I will fill in the recessed area with wood filler and sand smooth, then cover with vinyl flooring.
I see many who have built there own teardrop campers anchor the side walls intothe wood fram below the floor. I think I'm going to drill recessed holes in the side walls like I did in the floor and use heavy carriage bolts to secure the walls to the sidewall of the trailer frame.
I cut out the sidewall profile of my teardrop to see what it will actually look like. I got a rock trapped between the 2 sheets of MDO and it gouged the surfae of one sheet. Noting a little CPES and some wood filler can't fix.
Image.
Last edited by Tommy2tone_1999 on Mon Apr 06, 2015 3:46 pm, edited 3 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Mon Apr 07, 2014 9:02 am
The walls are clamped together, and now the edges need to be evened out.
The belt sander was taking too much time, so I broke out the electric planer to get things started, then finished up with the belt sander. Just as I was finishing up with the wall edges, the UPS truck showed up with mt doors from Vintage Technologies! This gave me a few more hours of energy and more to do :thumbsup:
I couldn't resist putting the door in position to get a better mental image. Man I can't wait to finish this project. 8)
I used the retainer ring for my doors to trace the outline for the door holes, then used my circular saw the plunge cut the straight lines and a jigsaw to cut the curved corners. It took me a few minutes to realize I needed the trace the outside of the ring that has the screw holes, but I got the holes cute and the doors fit fine. Now to put the doors away for a while until I'm ready to mount them.
One of my fellow scout leaders Adrian Fortier came over to give me hand mounting the walls. Later, I went out and marked the position of my cabinets. Time to break out the caulking for the floor to wall seams.
Last edited by Tommy2tone_1999 on Wed Jan 14, 2015 11:14 am, edited 2 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Mon Apr 14, 2014 1:26 pm
LOVE this thing.
Dry fit of the door now that the walls are up. I used the lag bolts to attach the walls to the trailer frame as well as using screws through the wall to the wood frame under the floor.
Installing spars.
Dry fit of the Fan-Tastic Fan.
Roof Spars up, time to sit back and think of the next step.
Smaller blocks between the spars to help the ceiling follow the curves.
Tommy2tone_1999
