aggie79 wrote:Cap'n Brad,
That is a very interesting and ambitious plan. I'm pullling for you to get it to work.
Take care,
tony.latham wrote:Something tells me you've got a plan.
RandyG wrote:I may change my plans of a piano hinge.
capnTelescope wrote:Don't try this at home, kiddies, unless you've got a CNC machine.
RandyG wrote:comparing it to a car trunk, the trunk is flat,your hatch is at an angle
RandyG wrote:Are you just going with two hinges or will you opt for more?
KCStudly wrote: Additional separation between the surface of the skin and the hinge point may be needed to account for degree of opening and curvature.
KCStudly wrote:That's an interesting detail to noodle out. Hope you are using some sort of 2 or 3D modeling.
KCStudly wrote:+1. Be careful not to under estimate the forces at work on a hatch hinge.
aggie79 wrote: I'm pullling for you to get it to work.
KCStudly wrote:"... Boy if you get that work I sure will be surprised. This ought to be good for a laugh."
KCStudly wrote: This will be interesting, and like we say, "somethun's gonna happen". Let's hope it works well!
AlgoDan wrote:Absolutely brilliant Brad, you come up with some interesting and challenging ideas. I sit here and watch and read your build in amazement.
AlgoDan wrote:Your hatch will work and seal and you will be smell the camp fire soon.
RandyG wrote:I guess a main point of all of this is to get the hinge point tucked under the end of the roof huh? The further forward you can get the hinge point makes for less of a pinch point and gives you a little more clearance. Or you can just extend your roof, is that the plan?
RandyG wrote:Or you can just extend your roof, is that the plan?
RandyG wrote:Why not try a search online for "deeper throat" just to make sure that name hasn't been taken.
Users browsing this forum: Google [Bot] and 3 guests
