KCStudly wrote:Any reason for making the notch between the 'C' part and the rib part so deep, and the 'C' section there so thin? Why not leave this "meat" in for added strength?
KCStudly wrote:Watching your progress is pretty cool.
mezmo wrote:,,,have you thought about using:
Car trunk lid hinges?
mezmo wrote:Just throwing it out there for consideration.
capnTelescope wrote:I've been contemplating a trip to a pick-your-part to do some research and/or part finding.
mezmo wrote:something like the above may be cheaper and stronger.
KCStudly wrote:What will keep the rain water from rolling down the roof and hatch into the top of the galley?
about hinge 3.0?KCStudly wrote:Why not leave this "meat" in for added strength?
It is a gate hinge. It's a gate hinge because that's the hinge I had. I'll get good heavy door hinges if this design goes to build.KCStudly wrote:... what looks like a gate hinge
Yeah. I'm not happy with that part, yet. Actually, it would be the top end piece of the hatch frame. I mentioned earlier about layout. This piece as-is doesn't positively locate the hatch ribs, which is very 'portant for good fit. Needs more drawing board work. There will be a hatch hinge 4.1.KCStudly wrote:...and perpendicular plywood mounting plate.
KCStudly wrote:Are you planning on using a harder wood for the hinge spar in the beta test?
I guess I'm not that used to rain. Central Texas has been in a drought since I got here, and in SoCal, well, the song says it pretty well.KCStudly wrote:Regarding the rain...
I've had occasional rain when I camped, never steady for a day or 2. Always checked the wx report before I took off. Never had a teardrop to worry about getting wet, either. This is all so new to me. OTOH, a nice rain shower is all part of the camping entertainment. Like watching your camping buddy get soaked trying to find a tarp in the back of his truck so he can cover up his sunroof hole, because he can't close the sunroof, because he can't find his car keys, which are hanging from his driver's door lock, right there in front of me, and I can't understand why he's going to all this trouble.KCStudly wrote:... what if there is a steady light rain for a day or more?
I don't either. That looks like something to rip your clothes or skin on. The great outdoors is already fraught with enough danger and discomfort without bringing it with you.KCStudly wrote:... because I don't want the rain gutters sticking out
Hang in there. You too will get finished one day. Well, OK, campable. You'll get campable one day. Poet Creek is calling you! I wish I was where it looks like I am. I so wanted to keep going when I did the loose assembly. Once I get this hatch settled, I think things will move pretty fast.KCStudly wrote:I wish I was at this stage in my build!
KCStudly wrote:Paraphrasing the quote, "no one has ever complained that they should have built heavier."
GuyllFyre wrote: KCStudly wrote:Paraphrasing the quote, "no one has ever complained that they should have built heavier."
Then let me be the first.
GuyllFyre wrote:Would make it easier to manufacture perfect side profiles.
capnTelescope wrote:I think the CNC started acting up after I replaced the original computer that died. It just finally became a really big PITA problem. I couldn't really pin down what the cause might be. Could it be that stepper I dropped once, the motor wire that got caught in the gears, weak stepper driver, the breakout board (a real black box for me), bad connection, the PC? How can it be a computer and be an intermittent problem? It was like staring into the abyss of a huge time and money pit. What if it needs another new computer? Do I go to the same store for another cheap used one? What if that one doesn't work either? Do I upgrade to a new desktop and put the one I'm using now to run the CNC? What if it doesn't work? What if I don't want a new desktop? What if Mach doesn't run under Win 7 or 8? What if none of this works? Aarrrrrrrghhhh!!! ( I want my mommy!) While I'm in the middle of this meltdown, the Ethernet SmoothStepper came to my attention. The size of the bet was a little bigger than another used computer, but I was disillusioned with the parallel port thing. Fortunately, the SmoothStepper appears to be working very well. (Knock on wood. ) I did have to install a second network card so I won't have to run SneakerNet for drawings, g-code, etc.
