RandyG wrote:I really like that table Tom! Did you use plywood for the legs and sides, or did you use dimensional lumber? Oh no, another project!
halfdome, Danny wrote:This isn't the simplest to build but it's the best I've ever worked on.
I bought a motorcycle lift table plan and modified it to my own needs.
It's in the lowest position (13" from the floor) and raises several heights up to 34" with the aid of an automotive floor jack.
The slot in the base is for a pallet jack so it can be moved anywhere, loaded or empty.
Got rid of the fork lift as it's not needed with this bench.
Using the trailer floor that's mounted to the chassis for your bench will kill your back.
Danny
