lighiting and 520 gi pocket stove.
Re: lighiting and 520 gi pocket stove.
Postby logman7777 » Wed Mar 12, 2014 11:33 pm
My Peak1 will singe whatever is in its "ring o fire" until warmed up. Biggest flare was a cold day and about a foot tall. Im sure with your experience you wont have any problems.. :thumbsup:
Im sure a 520 will behave similarly..
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Postby Wolffarmer » Thu Mar 13, 2014 2:08 pm
The 520/530 are a different beast. On your first light I would suggest an area that is not to flammable. And if you have a fire extinguisher keep it handy. These are things I seldom do. I would kind of keep a match near the the generator to help it heat a bit quicker. Flames 2 feet high are to be expected. well, maybe only 18 inches but they will burn your whiskers right off.
Randy
Wolffarmer
Images: 309
Postby logman7777 » Thu Mar 13, 2014 4:06 pm
That sounds safer..Maybe a genny preheat would help? :thumbsup:
logman7777
Postby Wolffarmer » Sat Mar 15, 2014 9:32 am
Something bad happen?
Wolffarmer
Images: 309
Postby Wolffarmer » Sat Mar 15, 2014 2:45 pm
You only had foot high flames when you fired up the catalytic heater? I find I need them up to my chin to get mine working good. Once they are running are pretty safe, as far as setting other things on fire. I have put wood shavings from my hand plane, less than .002 inch thick on it and they eventually char a little. Can even safely poor the fuel from a running one back into a fuel can. Just don't get them in an un vented area. CO poisoning gives a mighty big head ache. If you live. I know.
Randy
Wolffarmer
Images: 309
Postby logman7777 » Mon Mar 17, 2014 2:49 pm
+1 on the CO Poisoning :?
logman7777
