jseyfert3 wrote:Don't forget room for shock movement/tire expansion. Yesterday I was on some fairly rough roads and the teardrop went airborne at least once hitting a good sized pothole (that county must not have had enough revenue to maintain the highway in good shape. It was a state highway, the state should step in and help...oh wait, it's broke Illinois!) Unlike you I didn't remove any leafs, tires at 40 PSI. I'd still imagine they are going to compress before the teardrop goes airborne, and they will compress more with a leaf removed.
jseyfert3 wrote:You should be more then fine with 1x4s instead of 2x4 floor joists.
lthomas987 wrote:jseyfert3 wrote:You should be more then fine with 1x4s instead of 2x4 floor joists.
Yeah, BUT I have a stack of leftover 2x4.
jseyfert3 wrote:lthomas987 wrote:jseyfert3 wrote:You should be more then fine with 1x4s instead of 2x4 floor joists.
Good point, as long as weight is not a huge concern.
Users browsing this forum: Bing [Bot] and 14 guests
