such as
http://www.homedepot.com/b/Lumber-Compo ... 5yc1vZbqk5
Not rated for exterior.
Is that because it is not UV stable, and if so, could it be painted to overcome that issue?
Would there be other concerns?
Hartse25 wrote:I am in the early planning stages of my teardrop, just taking it all in and making notes about what I want to do. I want to keep my td light, I like the idea and cost of the frp over an aluminum skin. Could you just put the frp over your frame and foam without putting plywood over the foam? Would this be stable enough hold up shelves or cabinets? I was thinking maybe frp on the outside and plywood on this inside, mostly because of looks.
Thanks,
Erin
