absolutsnwbrdr wrote: I should have used oak.
KCStudly wrote:Zach, have you seen the aluminum inserts that capnT has let into his hatch ribs, similar to Grants sandwich ribs? Instead of starting over, if your short fix isn't working you might want to think about something along those lines. Kind of what you already added, except much longer. You could do a dog legged shaped insert that ties back into the rib segments further away from the joint.
capnTelescope wrote:I know where there's some open CNC time to get that done!
Kharn wrote:I'd go with a dog leg on the inside face of each vertical rib, cut to clear the horizontal rib and with a radiused turn (if the rib can't be relieved), and extending completely from the hinge to the gas strut's attachment point.
Users browsing this forum: No registered users and 55 guests
