Hi Dave, your trailer looks great! I would like to know how hard
Was it to bend the aluminum on top of your trailer.
I'm ready to pick up some and was worried that
.063 thick would be to hard to deal with. My trailer
Is 5 ft wide. Thanks!
camper4life wrote:I would like to know how hard
Is 5 ft wide.
camper4life wrote:Thanks for the advice Dave! I just drove home with two sheets of .063 aluminum for the top of the trailer. I picked up my sheets at Nichols Steel in Greenville, MS. They will roll my sheet if i need to for $50- $60 bucks. They cut me a deal @ $97.95 per 5x10 sheet since our shop does all the woodwork on their tow boats. I think I'll try to bend it myself since my smallest radius is 24". Wish me luck! Thanks again, Frank
McGuffin wrote:Hi Dave,
Just a quick question on how you fixed your door hinges.
Did you fix them by bolting them through on the side walls - or did you use wood screws. The reason I ask is because I would like to skin the inner walls with 1/4" veneer before I get around to fixing the doors on - I'm not sure I can do this if I have to allow for bolts coming through (if you understand ... )
Regards
Larry
McGuffin wrote:Hi Mallymall and Dave,
Thank you for the great advise. I am about to put the sides up permanently and am trying to figure things out in advance.
Mind you.... the build is going slow just now. Watching too much World Cup football. As I write this the US are putting on a great show against Belgium.
Great photographs Dave. I can't wait until we get camping too.
BTW I contacted Grant Whipp about the 4" corners of the doors as you suggested and he told me that it'll be problematic when it comes to fitting the "T" aluminium. So I have figured out a way to round them out to a 6" radius without wrecking everything ... hopefully
Larry
DMcCam wrote:Hi Everyone, and thank you so much Sharron!
It was a good weekends work with quite a few things accomplished. Finally got the hatch trimmed out and it seems to be a pretty good fit. Please excuse the squeeze out butyl tape, silicon caulking and smudges; I'm working fast so she'll get cleaned up later. For all those brave souls who are finishing with aluminum a few words of encouragement; patience will serve you well. Even though Grant's moldings are dead soft, it still takes a lot of work to make these tight bends. The stuff buckles and you'll need to hammer it out again and again with those dead-blow hammers. Eventually you'll get it if you take your time and work through it.
The driver's side trim with the hatch closed.
Hatch closed.
Here's the hatch open...yep, the struts are installed but not enough to keep it up. They are 120 pounders too. I'm guessing 130-140 lb ones should do the trick.
A couple of shots of the edge trim with the hatch open.
I installed the galley lights too.
Here's the passenger side door with the rain cap over the window and the drip gutter installed!
Same for the driver's side, wahoo!
I wanted to see how the drip gutter looked with the driver's door open; looks good yet needs to be tweaked a bit.
Thanks for following.
More to come,
Dave
BuildingForFun wrote:What did you use for the Drip Gutter Above the door and the Window cap?
Users browsing this forum: Bing [Bot], steve cowan and 16 guests
