"Check out the towing weight tables we provide per model or your vehicle's handbook for maximum braked and un-braked towing weights. Use these as a guideline. With a fully loaded trailer, braked or un-braked, you must be able to stop from 30km/h (18.64mph) on a dry road within seven metres (23ft).
Trailer brakes are not required unless total weight exceeds 2000kg. As another guide, don't tow an un-braked trailer which, when fully laden, weighs more than three-quarters of the weight of the tow vehicle." (I don't know how this compares to US regulations).
"Kia towing weights
These towing weights are sourced from the New Vehicle Distributor’s spec sheets. They’re based on vehicles sold new in NZ - spec levels and recommendations may vary with used imports. Some vehicles also require a transmission oil cooler be added for towing. It’s best to seek advice from your nearest dealer if required.
Soul 1.6 diesel (Plus & Burner) 2009 un-braked 550Kg (1212lbs). braked 1100Kg (2425lbs).
Soul 1.6 petrol 2009 un-braked 450Kg (992lbs). braked 1300Kg (2866lbs)."
