425 to 426.
Re: 425 to 426.
Postby doug hodder » Sun Oct 12, 2014 6:38 pm
Nope....a 425 has an 8.5 center on the tabs, 426 has a 9" and the 413 has a 12". Doug
Re: 425 to 426.
Postby Wolffarmer » Wed Oct 29, 2014 11:23 pm
It appears to me that latter 426s used the same tank as the 413s. Early 426s have their own tanks. I have 2 426Bs and their tanks are different. Also have 2 426Ds and their tanks look to be the same as 413s of the same time period. Though I have yet to try them. Some day I may.
Randy
Wolffarmer
Images: 309
Re: 425 to 426.
Postby Wolffarmer » Sat Nov 01, 2014 2:40 pm
I sure don't.
:o Randy
Wolffarmer
Images: 309
Re: 425 to 426.
Postby wagondude » Mon Nov 03, 2014 1:42 pm
In the mean time, you could just go with the propane adapter and be using it anyway. But get the hose for the bulk tank too. It's getting too cold in the mountains to run off the 1lb cylinders.
Bill
101137
wagondude
Images: 35
Re: 425 to 426.
Postby Weirdnerd » Sat Nov 08, 2014 11:31 pm
I don't know if the generator will reach the gas elbow, but if you have the 425 tank, and the 426 stove, you could try to position the tank in the place where the generator would fit, outline the tab locations with a fine sharpie and cut carefully with a dremel tool, not a dramatic change in design, but it may make your stove usable.
This is my build thread...
Weirdnerd's teardrop
Weirdnerd
Re: 425 to 426.
Postby Wolffarmer » Sat Nov 08, 2014 11:42 pm
I doubt if the 425 generator can pass enough gas. :lol: :lol:
To run more than the center burner, even if can reach it.
Randy
Wolffarmer
Images: 309
Re: 425 to 426.
Postby Weirdnerd » Sat Nov 08, 2014 11:52 pm
I guess he could rig a 426 valve assembly on the 425 tank.... may mean reduced burn time, instead of two hours, maybe one and a quarter?
http://www.oldcolemanparts.com/product. ... at=&page=2
Weirdnerd
Re: 425 to 426.
Postby Wolffarmer » Sun Nov 09, 2014 1:40 am
Probably most anything valve and generator from a 413 would work, heck the 426D and E uses the same tank and all as the 413
Wolffarmer
Images: 309
Re: 425 to 426.
Postby doug hodder » Sun Nov 09, 2014 8:31 am
It's not that tough to just find another stove, they're all over.
