My question is, will 18v and 340mA for 6 hours a day hurt the battery over the long run? Does leaving the panels connected in the dark actually discharge the battery? Would a 1N5822 diode wired into the positive lead prevent this? (Read about that on the internet too)
I can get a simple charge controller like this from HF, but prefer not to - just another link to break in the chain...
http://www.harborfreight.com/7-amp-solar-charge-regulator-96728.html
I had one of these panels for the longest time, just for messing around with:
http://www.ebay.com/itm/VW-Volkswagen-12V-Solar-Panel-Battery-Maintainer-OBD-Plug-USED-/271300142952?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2abfa768&vxp=mtr
(Basically it is a small 3W panel that specs out at 18V max / 170mA - I can vouch for the voltage, but no way to measure the amperage)
My new-to-me teardrop came with one as well, the previous owner used it to keep the battery up while in storage (direct wired to the battery). I wired the two panels together to see how much I can get in a typical AZ day - possibly enough to bring the battery up after a night of running the roof vent fan. (The fan draws the battery down from 12.5v to about 9.5v overnight). One panel in 6 hours of partly cloudy skies brought it from 10.5v to 11.6v, not bad for a little bitty panel.
I have a small battery charger that I can plug into an inverter-supplied outlet in the bed of the truck and top off that much in a couple hours of running the engine - so this isn't a huge deal - more of an ongoing experiment/study. I have no need for a generator and don't want bigger panels - these store neatly in the battery box on the tongue.
As always, thank you for your input/expertise!
