Modified 2+2 trolley top - Dinette Table - pg 15
Re: Modified 2+2 trolley top - Fiberglass applied - pg 13
Postby KCStudly » Sun Sep 21, 2014 6:34 am
As with all of your work, it looks like you are doing a wonderful job laying the glass down! :thumbsup:
Are you using a putty blade to push the epoxy?
Postby danlott » Sun Sep 21, 2014 12:14 pm
KCStudly wrote:Are you using a putty blade to push the epoxy?
I used a combination of a rubber squeegee, foam rollers and disposable paint brushes. On the mostly horizontal areas I spread the epoxy with the squeegee. On the vertical areas I had to put the epoxy on with a foam roller. On the inside corner areas I used a paint brush. After putting on the epoxy I then use the squeegee on all the areas to scrape off the excess epoxy.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby KCStudly » Mon Sep 22, 2014 8:39 am
Postby minuo » Sun Nov 16, 2014 12:03 am
Looking great Dan, I appreciate the photos and all the detail as you go along.
I'm also a fan of your Sketchup models, you do great work. Out of curiosity, have you ever shared (or thought about sharing) the model for your Hoplite Traveler? I don't have the money for a real build yet, but its fun to play around digitally and dream!
:beer: Cheers,
Nick
minuo
Postby S. Heisley » Sun Nov 16, 2014 12:49 am
Awesome planning, detail, and work, Dan. :thumbsup:
I can hardly wait to see it in a campground!
Postby Vedette » Sun Nov 16, 2014 3:00 am
Looking Good Dan! :thumbsup:
You are lucky that your temps are not the same as ours, as you glass would not have kicked??
-12 C last night. Cold and clear today had to rake and haul leaves to the dump.
No time to work on Kermit. :cry:
Good Roads
Brian & Sandinight
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby GreenViking » Mon Feb 16, 2015 8:00 pm
Dan! Really inspired by your build. I love the trolley tops and am trying to figure out some ways of creating a hard-shell fold up trolley.
So how are things at this point with your build? Any pics you can share to update us? PLEASE!!!! :)
Best,
GreenViking
Postby cbgaloot » Tue May 12, 2015 3:36 pm
It's already an awesome piece of craftsmanship, and it ain't even finished yet.
cbgaloot
Postby gersus » Fri May 15, 2015 9:17 pm
I've really enjoyed reading your build thread! Looks really good! What weight of fiberglass did you use?
gersus
Postby ZoNiE » Fri Nov 20, 2015 10:09 pm
This one is gonna Rock.
2010 Skyline Nomad. Heavily modified. 400W solar. Honda EV4010.
2009 Sport Trac Adrenalin AWD V8.
Next TT Project: Alde Hydronic Heat.
ZoNiE
Postby danlott » Sun May 22, 2016 11:14 pm
It has been a long time since I have posted much on this site. I have been working on my trailer off and on, guess I need to post some pictures. I have been working on various parts of the trailer from the dinette, tongue box and electrical. Today I will post some pictures on the dinette.
I had to frame under the side sections of the dinette to allow for weight support and also to allow for cutouts to access the area for storage.
This is the dinette before I laid out for the cutouts in the side storage areas. The back part of the dinette also has storage, but that will be accessed from compartment doors on the outside walls.
I cutout a template from 1/4" inch plywood and marked the cutout locations on blue tape.
I then used a jigsaw to cutout the storage lids. I took my time and went slow to get nice straight cuts. I also used a 1/8" radius router bit to ease the top edge of the cutout holes.
I glued the plywood to the support framing.
I used the 1/8" radius router bit to ease the top and bottom edges of the storage lids and then set them in place.
Dan
danlott
Images: 264
Re: Modified 2+2 trolley top - Dinette storage - pg 14
Postby KCStudly » Mon May 23, 2016 8:03 am
Looks good. Nice work! :thumbsup:
Postby Wolfgang92025 » Sun May 29, 2016 1:59 am
Dan,
Glad to see you are still at it.
Keep up the good work..... :thumbsup: 8)
Wolfgang
Wolfgang92025
Images: 651
Postby S. Heisley » Mon May 30, 2016 6:44 pm
Wolfgang92025 wrote:Dan,
...Ditto. ...Hope to see you out camping in the new rig!
Postby danlott » Mon May 30, 2016 11:33 pm
Wolfgang92025 wrote:Glad to see you are still at it.
Still going, just slow. I hope to finish it up this year....
Dan
danlott
Images: 264
Users browsing this forum: smeerkees, stolkisl and 13 guests
