Shadow Catcher wrote:The fitting is right next to the gas water heater and right above it is a gas detector and above that is the cook top. I found that I have a flaring tool so I will be flaring the gas line Y and will periodically leak test the Bullfinch. Interestingly one recommendation is to use teflon tape on the thread of the compression fitting.
Shadow Catcher wrote:The gas point has been in since I started this thread, I check it and all of the other joints (flare) for leaks each spring. I understand US standards but the gas point meets UK and presumably EU standards.
Users browsing this forum: Google [Bot] and 9 guests
