Hi all. First of all, I want to thank tnttt.com and its members for some great ideas and validation (or rejection) of some of my own ideas. You all have terrific experience and should be commended for your willingness to detail and share! In return, I thought I’d do a build thread for my 6x12 Vee motorcycle road race trailer. Sorry in advance for being an engineer-type with too much time on my hands. All constructive comments are well received.
I call it a Toy Hauler Lite because I will not need running water or indoor cooking. Tracks typically have showers and rest rooms. Any cooking will be done outside. Race season is typically April-October so I will not need extreme heating. Also, I LOVE summer heat except for sleeping so air conditioning is only needed at night when temps cool off.
Design criteria:
1. Total Build Cost: <$9000
2. Must fit into my standard garage (7’ entry height)
3. 6’ interior height
4. Must be capable of carrying 3 road racing motorcycles AND sleep 2 “on the road”
5. Must be able to sleep 5 when set up in the pits
6. Some AC and Heat
7. Able to be towed by my Audi Q5 Diesel (rated at 4400 lbs/440 TW)
8. Still have room for all the gear associated with racing, including toolboxes, safety equipment, stands, extra wheels, etc..
9. Must look “good” in order to attract/retain sponsors
10. Built to last…I don’t want to do this again for several years
So for quite a while my criteria seemed impossible. In order to fit 3 bikes, gear and have any room left over for people a minimum size of 6x12x6 Vee is required. Unfortunately, most every 6x12 Vee with a 6’ ceiling has an exterior height of 90” or greater…no way to fit under my 82” garage opening. I spent dozens of hours poring over the specs of virtually every trailer manufacturer in the US. Each time I found something close I contacted the manufacturers and dealers. Due to my difficult criteria I had to ask for a few small modifications to their standard build and in almost every case they either ignored my request or said no thanks.
Finally, I found my base trailer and with the help of the first, IMHO best and cheapest Wells Cargo dealer in the US -Don Randall Wells Cargo- I custom ordered the single brake axle 6x12 Vee version of this:
http://wellscargo.com/wellscargo-trailers/motorcycle-trailers/te-series/overview/
Modifications/options I specified were to add 3” interior height, install an RV style door with window and screen, 1 piece AL roof, brakes, and do not install floor tie downs.
Here’s 3 pictures coming home with it from the IN factory in early December after a 10 week build time. A quick note on fuel economy...empty I got ~19mpg which compares favorably to my previous 5x8x5 Vee which got ~20.
Next up, into the garage!
