bobhenry wrote:Best I could do Ed !
http://www.nationalserroscotty.org/rebuilds/scotty8/index.html
Looks kinda like a benroy that they started the galley hatch taper too soon
bobhenry wrote:Unless you have inside storage 365 days a year do yourself a favor and forget woodies. They are beautiful and I love them but after the heart break of watching Chubby being attached by the weather I went to frp skins for my next two builds. Yes there are a couple coatings that will help but the Midwest winters are not kind if they are left out. Just my two cents worth.
Rooky wrote:I saved this from the site a couple years ago. It is one of my favorite profiles. Hope it helps.
ctstaas wrote:Hi TrailerEd, I like what Bob Henry said about a towing tree. If that tree were a simple steel Tee with a wooden cabin on top- plenty strong. Mine is overbuilt and it wasn't necessary. A lot of extra time, cost and weight and will be good to go 20 years after I'm gone, so it depends on what you want.
Enjoy, Chris
rowerwet wrote:I know it would make an odd shape, but you could avoid a tounge all together by making the four corners of the tear cross section taper in together to the coupler, the extra enclosed area would make great storage. Or you could make laminated beams in the same shape and have them flow into a normal tear shape.
With the whole shape flowing to the coupler the walls would be the load bearing structure and very little would need reinforcement or lamination.
rowerwet wrote:I know it would make an odd shape, but you could avoid a tounge all together by making the four corners of the tear cross section taper in together to the coupler....
