Smiles to go! Updated 8-2 new pics! First trip!
Re: Smiles to go
Postby booyah » Tue Jun 02, 2015 12:49 pm
Thanks again KC, i did a quick excel spreadsheet on it, and it turns out the factory wheels (21.9" diameter) vs say the 27 wheel you quoted is the difference between 55mph and 68mph at the same wheel RPMs.
Makes a pretty decent difference
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Re: Smiles to go
Postby KCStudly » Tue Jun 02, 2015 2:48 pm
:thumbsup: :D
Re: Smiles to go
Postby booyah » Sun Jun 07, 2015 5:46 pm
So, its been a little bit since any updaets... Here goes
Put up the back bulkhead (yes, very smalkl galley on this design)
Wired everything up (two 12v with 2USB chargers under the shelf/kid bunk, Porch light, fantastic fan, and a reading lamp)
and insulated
then sealed up that wall
booyah
Re: Smiles to go
Postby booyah » Sun Jun 07, 2015 5:50 pm
Then much on the other side, this one took a little longer, I had to go back to the store for more wire. Over 200ft of wireing in here just for my little electronics. I added another run to this wall for a second 2x12v +usb chargers in the galley
Next up is the roof spars, and then I start bending birch...
Really excited to see things comeing together, after how long I felt like I worked on the platform before I saw any real results.
booyah
Re: Smiles to go
Postby booyah » Tue Jun 09, 2015 9:00 am
quick update
Roof spars in up to the point the ceiling fan goes in!
ceiling fan mount is getting built tonight and installed, and its possible the interior ceiling will get installed tonight as well
I would really like to get the ceiling on before this weekend, not sure if that is possible or not right now
booyah
Re: Smiles to go Lots of updates, more better pics :)
Postby Gpike » Tue Jun 09, 2015 11:48 am
Your moving right along! Looking good too.
Gpike
Images: 31
Postby rebapuck » Tue Jun 09, 2015 12:22 pm
Have you considered a tire/rim to match your tow vehicle? It would eliminate the need for a spare on the TD.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby booyah » Tue Jun 09, 2015 1:38 pm
@rebapuck
Yeah I considered it briefly, but it would require me changing out the Hubs on the trailer, and doing something crazy for a spacer for the offset as the TV is a FWD Scion XD.
At this point, I think I'm just keeping the stock wheels, and looking at a replacement in the future. For now I just wanna get out and camp! :thumbsup:
booyah
Postby booyah » Tue Jun 09, 2015 1:39 pm
Gpike wrote:Your moving right along! Looking good too.
Thanks Gpike, I was just looking at yours earlier!
booyah
Postby booyah » Fri Jun 12, 2015 9:10 am
Quick update
Got the panels for the interior ceiling measured, cut and glued together.
Got the fan box built and installed.
Got the last roof spar built
Waiting on a friend to come over and give me a hand installing the ceiling panels, as a 10ft long piece of 1/8" wood is kinda hard to maneuver by oneself :)
booyah
Postby booyah » Mon Jun 15, 2015 7:53 am
More better pics :)
got the interior ceiling in yesterday with the help of a friend
then got to work on the insulation
booyah
Postby booyah » Mon Jun 15, 2015 7:54 am
then I finished up the insulation
booyah
Re: Smiles to go! Ceiling and insulation in!
Postby booyah » Thu Jun 18, 2015 12:37 pm
No new pics, but...
Hole for ceiling vent is cut on inside skin
Glued and sealed up the wall insulation in the galley area, and installed interior wall.
Poplar 1x2 double spar is installed (drilled from the outside with 3.5" deck screws and glued)
Hatch ribs cut (WOW that sucked) 8 from 1/2 plywood. Plan is to glue them together for 4x1" ribs.
Glued hatch ribs.
All the cross members for the hatch cut and drilled (kregg jig)
Sealed down the back of the interior ceiling
Working on getting the hatch built up tonight, and if I have time getting some of the exterior skin on.
booyah
Postby S. Heisley » Sun Jun 21, 2015 8:13 pm
Keep going! We're watching! :SG
Postby booyah » Mon Jun 22, 2015 8:24 am
More pics later today. Got over my funk at least for now.
Hatch is built
outside is skinned back to the hatch
I need to trim the edges and cut the ceiling fan vent, then skin the hatch.
Then I'm filling seams, and the few small holes from my flubs. Then its sanding/epoxy and fiberglass
getting there
booyah
