Dexter Toflex axles are available in 45, 32, 22.5, and 10 degree "down" angles, 0 degree angle, and 10 and 22.5 degree up angles.DrewsBrews wrote:Torsion axles can be ordered with just about any starting angle you would want, within reason, in order to give you the desired amount of drop (don't order one of the generic prebuilt ones in that case).
UCF America Flexiride torsion axles are splined and can be adjusted.DrewsBrews wrote:At one point I had heard a company made torsion axles that had a splined shaft that allowed you to set this yourself but I am unsure if they are still available.
Dexter provide specs for deflection for "no load", "full load" (axle load rating), and "shock" load (potholes) conditions. UCF has "static" load deflection information for a few of the different torsion arm angles possible.DrewsBrews wrote:Keep in mind the sag that will result from the rated load placed on them so the starting angle you order should be taller than the desired finished ride height. I have not had a torsion setup, but I imagine there may also be some "break in" and the ride height may drop a bit more after put into service. I have also heard that it is good practice to store the trailer on the jackstands so the torsion axle does not further sag or develop a lean with age.
