go ahead, call me crazy !
Re: go ahead, call me crazy !
Postby dave campbell » Sun Sep 13, 2015 9:32 pm
thanks OP8 for the great info again :beer:
McGuffin wrote:Hi Dave,
That's a real work of art. It is a pity in a way to cover up all that lattice of steel so beautifully wrought!
Where is the original one that you are replicating and where was it built?Larry
thank you so much ! definitely more art than science here---- the missus has always maintained it's like a viking build. a very cool photograph.
the original 'mystery trailer' we found online while looking at images of vintage trailers, and the spark caught. further research revealed that it is a one of a kind, but appears to be factory made in 1936. there are no builder's hallmarks. the company that did a full restoration is located in california---called sierra trailer restoration. where the trailer resides now i have no idea, but i know where it's twin will be soon !
:beer:
renaissance man-----MUST....MAKE......EVERYTHING !! (wife interjects here---"EXCEPT MONEY !")
dave campbell
Postby dave campbell » Sun Sep 13, 2015 9:39 pm
well, i welded the cage to the base today. i chose 10 contact points and had at'er. also templated the front floor section, and cut the plywood. tomorrow it will be installed along with the rest of the floor
cage welded to base.JPG (50.83 KiB) Viewed 1639 times
:beer:
dave campbell
Postby S. Heisley » Mon Sep 14, 2015 8:46 pm
I can also see some similarities with Viking shipbuilding:
Congratualtions and well done
:beer:
Larry
Oh! M'gosh! You're right! :o :thumbsup:
Postby dave campbell » Tue Sep 15, 2015 3:51 pm
update for today--- floor is in !!
bottom layer is 1/2 factory grade, exterior ply and the top layer is sanded 5/8 exterior ply. next i will be making paper templates for the door jambs, and using 1/2 ply scraps doubled up to fill the voids in the two bulkheads.
thought of a decent name for this unit------ Mahi-Mahi :beer:
like a mahi-mahi.JPG (63.38 KiB) Viewed 1558 times
the cage.JPG (61.39 KiB) Viewed 1558 times
dave campbell
Postby KCStudly » Tue Sep 15, 2015 6:24 pm
Looks great! Keep plugging along. :thumbsup:
Postby OP827 » Tue Sep 15, 2015 6:31 pm
:thumbsup: Great! Did you use bunch of self-tapping screws to fix the plywood to steel?
OP827
Images: 405
Postby dave campbell » Tue Sep 15, 2015 7:23 pm
KCStudly wrote:Looks great! Keep plugging along. :thumbsup:
thanks !! 'plugging' is fast becoming shambling which then leads to straight up knuckle dragging-- i understand.
OP827 wrote::thumbsup: Great! Did you use bunch of self-tapping screws to fix the plywood to steel?
yes i used self tapping screws (#10 X 1) and PL premium on all the beams, but quite honestly about 7% of the screws were bunk. i pre-drilled holes to make it easier as they just wouldn't grab. even then many tips broke off in the hole, which then i had to re-drill. over about 120 screws---4 lost their tops. i used a regular 18V drill, and not an impact driver to reduce screw damage. the second layer of ply is held on with superglue and deck screws at about 7" intervals, except in the doorway where they are closer to 4" apart---and the seams between the layers are all staggered. floor thickness is 1 and 1/8"
after making ram-board templates, i whipped up 18 chunks of 1/2"ply to be doubled up in the bulkhead. that got me 1/4 of the way through this phase
bulk bits.JPG (44.19 KiB) Viewed 1532 times
some peanut-butter---
bulk bits3.JPG (51.09 KiB) Viewed 1532 times
and voila !
bulk bits2.JPG (66.58 KiB) Viewed 1532 times
dave campbell
Postby dave campbell » Tue Sep 15, 2015 10:10 pm
i'm not one to take a selfie but i couldn't resist today ;)
currently typing with my hand in a "c" shape from holding the jig saw for so long
night all :beer:
dave campbell
Postby dales133 » Wed Sep 16, 2015 12:59 am
Looking good and yes it does look a bit like a mahi mahis head at the front.
Keep the pics coming
dales133
Postby dave campbell » Wed Sep 16, 2015 8:12 pm
dales133 wrote:Looking good and yes it does look a bit like a mahi mahis head at the front.
as cool as it sounds it doesn't really roll off the tongue. next name up, and believe me we have discussed many-----is ORBIT. fun. simple. fun to say. orbit---meep morp.
has metal connotations, hints of tool. it's a noun. it's a verb. it's a shape. it's what we do with camp spots, like comets....
ok enough of that.
today was a slog !~it doesn't look like much but a LOT of time went into the bulkhead bulkout program.
first i completed the core----templating with ram board---transferring and cutting----re-marking and belt sanding to tweek the fit. X 72 different pieces.
from the factory they would have been 72 same pieces, but i'm not a factory---just a machine 8)
bulkhead core complete.JPG (67.37 KiB) Viewed 1463 times
after the core, then the 5/8 wrap to both sides, for a thickness of 2 and 1/4". the door will be well hung
bulkhead bulkout.JPG (44.23 KiB) Viewed 1463 times
meep-morp :beer:
here's view of the jamb from the outside. plywood all the way through
bulkhead view from outside.JPG (28.69 KiB) Viewed 1463 times
dave campbell
Postby dave campbell » Wed Sep 16, 2015 8:22 pm
more to say.....
here's a shot showing the two sides of the door, and to the right of the jamb is the backing for the wall up front
door jamb morph.JPG (18.1 KiB) Viewed 1493 times
once i had one side flowing to my satisfaction (used the old eyeball, a pen, then jigsaw followed by 4"grinder with 40 grit sanding pad)
then i made a template, flipped it around to the other side, and copied
bulkhead template.JPG (53.74 KiB) Viewed 1493 times
somewhere there is an algorithm with which you can calculate calories burned by measuring this heap
:beer:
dave campbell
Postby dave campbell » Wed Sep 16, 2015 8:30 pm
forgot to mention--- i did a little research on spray insulation today. if i get it done locally---650 $ minimum charge !! plus i have to get the trailer to them. if i get the stuff from a distributor in burnaby--across the water--then maybe 400 after taxes and delivery--and i get to do it myself at home :beer:
dave campbell
Postby dales133 » Thu Sep 17, 2015 1:06 am
Looking good dave.
Another name worth considering....Dorado...the other name for mahi mahi ;)
There might be someone not to far from you out of town willing to travel for tbe spray foam
dales133
Postby McGuffin » Thu Sep 17, 2015 5:33 pm
Hi Dave,
Giving something like that a name is tough.
:thinking:
How about using an old Norse / Viking name?
Here's a nice one: "Astrid".
Larry
McGuffin
Images: 211
Postby McGuffin » Thu Sep 17, 2015 5:46 pm
Hey Dave,
Just to mention, I'm getting mine spay insulated in a couple of days. The roof void only of course. I'm being charged €175 for the job and the guy will be driving 30 miles to me to do it.
I did think of doing it myself but the only stuff I could get was the foam in large aerosols that builders use. This apparently is not the same stuff.
The foam in the cans is "open cell" foam which is porous (try to envisage a stiff sponge) and not a great insulater. The stuff the spay professionals use is "closed cell" foam which is waterproof and has more insulation value.
It all looks great anyway .... keep up the good work.
Larry
McGuffin
Images: 211
Users browsing this forum: No registered users and 26 guests
