2" or 1-7/8" ball???
Postby zimbar » Mon Jul 27, 2015 8:20 pm
Hi folks,
I'm starting to plan for my first Teardrop trailer and I've been looking though all the posts I can get my hands on. My '09 Charger has a hitch on the back with a 1-7/8" ball. I use it to tow my little 12' aluminum boat with. In my planning for the teardrop, I've looked at Northern Tool's and Harbor Freight's trailer that so many of you use. Both have a 2" coupling, and all of the trailer plans I've seen call for a 2" ball as well.
My question is....Why 2", what's wrong with changing out the coupling for the ball I already have?
Thanks,
Patrick
zimbar
Re: 2" or 1-7/8" ball???
Postby asianflava » Mon Jul 27, 2015 8:28 pm
Whichever one you choose, stick with it, this will prevent any mixups like using the 1 7/8in ball on the 2in coupler. Went to a gathering where someone's T@B came off the hitch because he accidentally did this. I like 2in because there are many more trailers that use it.
asianflava
Postby Shadow Catcher » Mon Jul 27, 2015 8:32 pm
I went with a 2" ball and because I wanted to use a bulldog hitch because this happened with a conventional hitch.
90578
Postby zimbar » Mon Jul 27, 2015 8:38 pm
Bulldog hitch???
I take it that a bulldog hitch is stronger than a regular hitch?
zimbar
Postby KCStudly » Mon Jul 27, 2015 8:57 pm
Bull Dog hitch is more secure because of its design. If you look at the last picture of this etrailer link you can see how the socket is hinged at the front to open, yet when closed it fully encases the ball with beefy casting (... maybe forging?) and has a locking collar that encircles the two halves holding them together. Unlike a std. coupler with a stamped steel tab that can go out of adjustment.
Postby GuitarPhotog » Tue Jul 28, 2015 10:28 am
I have 2 trailers, one with a 2" and one with a 1-7/8". I just keep two ball carriers, one for each size. Each trailer requires a different amount of drop, so they are easy to tell apart.
I don't see that this is a problem if you pay attention.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby DrewsBrews » Tue Jul 28, 2015 9:51 pm
I had heard a 1 7/8" ball works with a 2" coupler, but I always had my doubts... enough that I won't do it myself on purpose. The coupler latch has an adjustment and if it is loose the extra 1/8" can make the difference between a noisy coupler and watching your trailer freestyle down the road.
1-7/8" is somewhat standard for light weight trailers, but 2" seems more widely used. Either should handle the weight of your average TD fine . You can swap out the coupler on a trailer for about $20. Which is about half the price of a convertaball (easy to swap between ball sizes) and less prone to mistakes if you stick to one ball/coupler size.
I did purchase a convertaball so I'd have the right size if I happen to spot a deal on the side of the road I can't pass up. But I plan to stick to one size on my trailers.
DrewsBrews
Postby zimbar » Wed Jul 29, 2015 7:00 am
DrewsBrews wrote:I had heard a 1 7/8" ball works with a 2" coupler, but I always had my doubts... enough that I won't do it myself on purpose. The coupler latch has an adjustment and if it is loose the extra 1/8" can make the difference between a noisy coupler and watching your trailer freestyle down the road.
Thanks DrewsBrews.
I think I'll stick with the 1-7/8 ball, since as you say it should be fine for a TD.
Zimbar
zimbar
Postby booyah » Fri Sep 04, 2015 2:41 pm
I have both a 1 7/8 ball and a 2" ball. I leave the 2" on the bar, but have switched out to the 1 7/8 when I needed it to tow a tiny utility trailer.
Like everything, make sure you have the one you need, and dont change it unless you NEED to
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby Gerdo » Sat Sep 05, 2015 9:33 pm
A lot of trailers have a bolt on hitch mount. If you want the simplicity of one size ball, swap one of the hitches to match the other.
2" balls are usually rated higher than the 1 7/8 but that shouldn't be an issue with a TD.
Personally, the HF hitch is kinda strange and I swapped mine out for a nice Reese.
Gerdo
Images: 156
Postby mikeschn » Sun Sep 06, 2015 3:58 am
My HF trailer came with a 1 7/8" hitch. It seems to work just fine, so I never changed it.
Images: 479
Postby DrewsBrews » Sun Oct 04, 2015 11:49 pm
slowcowboy wrote:2 and 5-16 for slow.... :thumbsup: it wont fit most thieves trailer hitches on there cars!
What stops them from just dropping it on their smaller ball and taking off?
DrewsBrews
Postby lrrowe » Mon Oct 05, 2015 4:58 am
I made the mistake of driving over 350 mi round trip with a 2 5/16" coupler on a 2" ball. I had the obvious play in the connection but made it home ok. I do consider my self lucky (and stupid for not being more careful). I guess that is proof that a smaller ball can work for a thief.
Bob
lrrowe
Images: 439
Postby Padilen » Mon Oct 05, 2015 8:33 am
I have 1-7/8, 2, and 2-5/16 and pintle. Old school of thought was/is (?) 1-7/8 for light trailers around/under 3000 pounds loaded. I use 1-7/8 on things like wood splitter and row boat trailer and kayak trailer. My CT is 2". But since I have all sizes of balls already it's not worth my time and money I do not have to make the change to all 2". I do not think I've used the wrong ball but have forgotten to latch the coupler on a few times.
Padilen
Postby Andrew Herrick » Wed Sep 21, 2016 12:33 pm
1-7/8-inch ball couplers are either rated for 2,000 lbs (Class I) or 3,500 pounds (Class II). 2-inch balls might be Class II - Class IV. Most teardrops can be towed safely with a hitch of just about any size because very few weigh 2,000 pounds or more. What's more important is the tongue weight rating.
With that said, people seem to trust 2-inch ball couplers more. Just marketing. And they're more popular. So if you plan to sell it one day, you might consider a 2-inch coupler just 'cause.
A few of my builds:
Andrew Herrick
Images: 15
