TimC wrote:I've seen some nice results of papering with maps on the interior walls of teardrops. I can't find any references to how they accomplished it. Anyone have an suggestions? I'm thinking topo maps and road maps. Wallpaper paste? Sealed or unsealed finish? I'm not going for perfection, rather, I'm thinking of using some old used maps. Wrinkles are OK. Curled up edges... not so much. Thanks, Tim
lrrice wrote:There is stuff called Mod Podge we used to use to stick pictures to wood don't know why it wouldn't work for this too.
S. Heisley wrote:lrrice wrote:There is stuff called Mod Podge we used to use to stick pictures to wood don't know why it wouldn't work for this too.
There are various types of Mod Podge. If I were to try it, I would use the outdoor one that is waterproof. Also, the surface that it is being used on should be waterproofed in some way so that no water gets in between the surface and the item being glued on. (That's an automatic thought to most of us; but, some might not think of it.)
http://www.amazon.com/Podge-CS11220-8-O ... B001681ZA4
TimC wrote:S. Heisley wrote:lrrice wrote:There is stuff called Mod Podge we used to use to stick pictures to wood don't know why it wouldn't work for this too.
Thanks for all the suggestions folks. For now I have just painted the interior walls. After finishing most of the cabin interior I now realize there is very little wall space for maps anyway. I will keep the mop podge stuff idea in the back of my mind as I think I will pick up postcards as I travel and glue them to available wall space. Can't wait until I start my travels. Probably next spring as we are expecting freezing temps in a few days and I still have weeks to finish the TD.
lrrowe wrote:TimC wrote:S. Heisley wrote:lrrice wrote:There is stuff called Mod Podge we used to use to stick pictures to wood don't know why it wouldn't work for this too.
Tim, you just gave me an idea. Why not use corkboard for the back splash. Then one could pin postcards, photos and what not on them.
