dales133 wrote:Should be able to get it done less than that.
I know its more expensive here and 80 -100 bucks an hour is about the norm for fabrication here
Sent from my SM-N910G using Tapatalk
JaggedEdges wrote:Okay, had a quick think about what I'd do to do it on my own, I think I'd use the weight of a car and "scrap" lumber to press them into shape... basic idea would be that you use 2 jacks to put car weight on a 4x4 that's pressing the metal down against another 4x4 underneath it. BUT panel, lower 4x4 have to be constrained from moving, and the top 4x4 has to be chained or have a strut bolted into the ends of the lower 4x4 so it can't move horizontally. Also a brace might be necessary in the middle to stop bowing. Though you could also constrain movement by say 4 2x4 braces to the bottom ledge/stop that the panel is resting against. I think you'd wanna do this on a piece of thick OSB or scrappy ply to nail everything down to.
This is not a fully developed idea, there's a lot of detail and safety precautions that need to be thought through in situ. If it's scaring you already, don't do it, if you're going "yeah, yeah, and this, and that" then rely on own experience to carry it through.
In general, when I've needed a lot of force or weight, I've used a vehicle as a tool, if that's not enough I've used a 10 ton jack against a beam in the basement, if I've needed immovable objects to exert extreme force against, I've use a large tree or the house.
