noseoil wrote:If someone would make a 2000 BTU AC window unit, that might be possible. If the current draw was below 200 watts with a compressor running (under 20 amps at 12 volts), the idle load was reduced to about 5 amps (or less) for the fan, it might be possible to run one over night with a battery. The problem is, there's no market demand for a unit this size & initial cost of the unit would be high.
It's still a tough question to deal with!
aggie79 wrote:Here's a 2500 Btu unit: http://www.climaterightair.com/products/climateright-2500-btu-mini-ac-heater.html for $399.
vigilant1 wrote:aggie79 wrote:Here's a 2500 Btu unit: http://www.climaterightair.com/products/climateright-2500-btu-mini-ac-heater.html for $399.
Pretty neat. About four times the cost per BTU of a typical $175 5K BTU window unit, but everything is in one box with simple "in" and "out" ducting fittings already provided.
I'm surprised that it takes 480 watts to run it, that seems high compared to the regular "window shakers" which move about 10 BTU per watt.
Agreed. Of course, not a significant issue at night (unless parked over a hot, black parking lot, etc), but in the daytime getting into the shade (or putting a light colored awning over the rig) would make a big difference.vigilant1 wrote:daveesl77 wrote: I guess I need to go out and see if it will crank up on its own, but I think I'm going for the capacitor simply to help it out.
Dave,
It would be interesting to see if it will crank, and the current draw (DC amps) when it is running. While the compressor will draw a a lot of juice to start, it is for such a short time that I don't think it will significantly impact the total available running time on battery (unless it is cycling on and off every 5 minutes). BTW, if the "hard start kit" capacitor provides lot of current as quickly as the motor calls for it, it probably helps reduce wear/heating of the compressor motor (vs waiting for a genset to come up to speed)Yes. I'd guess that scaling down the compressor results in less and less efficiency (e.g. volume reduces faster than the friction-inducing swept area of the pistons/vanes/whatever).aggie79 wrote:It is probably a situation of diminishing returns electrically. The blower on the predecessor had the same CFM as my window unit, so even though the compressor demands scaled down, the power to run the blower is about the same.aggie79 wrote:BTW, I mentioned the direct sunlight condition above. I believe the radiation heat gain would be in addition to any convection heat gain.
daveesl77 wrote:I just ordered the spp6 from Amazon for $11. What the heck, worth a try. I did find a youtube video where another teardrop guy put this same thing in a Haier 5k and ran it from his Honda 1000 without any problems. We shall see.
I'd guess the circuit breaker tripping was all about a flow of current that exceeded the unit's capacity, and not due to a weak battery. When you get the spp6 installed maybe it will start okay. If you get a chance: what's the circuit breaker rating on the inverter, and what is the amperage/VAC or wattage rating of the AC unit (as shown on the dataplate)? Sometimes they show starting current, but often it's just the running current. For example, here (http://products.geappliances.com/appliance/gea-specs/AEM05LV ) is a low-price GE EnergyStar 5200 BTU unit with a running current of 3.7A at 115VAC, or about 420 watts (= 35 Amps at 12 VDC, plus any conversion losses). I'm guessing the starting amperage is probably double that, if no "hard-start" kit is used.daveesl77 wrote:Oh, I did just try doing a direct run from my inverter, but it tripped the inverter circuit breaker. I then realized the battery had not been charged in quite some time, so now charging it and will try again tomorrow.
