Sealing a kerosene lantern tank
Postby scottinwv » Sun Oct 02, 2016 6:52 pm
I have an old Feuerhand lantern which sat for years on the vanity in the bathroom as a backup in case of power outage. Came home to find the counter covered in kerosene after the tank leaked. Is there any easy way to seal a tank or is it just a display piece now?
Thanks in advance,
Scott
scottinwv
Re: Sealing a kerosene lantern tank
Postby Philip » Sun Oct 02, 2016 8:04 pm
Leaking from a seam or pin hole from rust?
Philip
Postby scottinwv » Sun Oct 02, 2016 8:38 pm
Bottom seam. I'm hoping there is some sealer that the kerosene wouldn't destroy, I don't want to destroy the exterior patina. If it can't be sealed, it will just be a dry lantern on a display rail in the kitchen.
scottinwv
Postby Philip » Sun Oct 02, 2016 9:01 pm
Use a fuel tank sealer. YouTube has many videos on just about all brands on the market.
If it was a pin hole I would suggest soldier. I have repaired a few tractor tanks that way.
Philip
Postby scottinwv » Sun Oct 02, 2016 9:05 pm
Thanks! I didn't know there was such a product!
scottinwv
Postby KCStudly » Thu Oct 06, 2016 9:29 am
I was of the impression that typical tank sealing coatings were intended to seal raw steel against rust, not intended, nor capable of forming any significant pressure seal; but I would be happy to be shown otherwise. 8)
Images: 8102
Postby dogscats » Thu Oct 06, 2016 9:53 am
J B weld from the inside. Add sand / small nuts '. Shake to remove rust.
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby Treeview » Fri Oct 07, 2016 9:15 am
I've used JB Weld epoxy for metal on many fuel tanks.
Magnesium on chain saws
Plastic for a hedge trimmer
Plastic saddle tanks on a pickup
Steel on a 60 gallon diesel tank for a large truck
Success is from good surface prep. Solvents to remove old remains. rough up the surface. Clean with soap and water. Kepp the repair warm
Treeview
Images: 30
Postby Tomterrific » Fri Oct 07, 2016 10:23 am
Gas tanks for vintage motorcycles are frequently repaired using interior coating. Try searching Red Coat. Stay away from Kream as folks have problems with that, for some reason.
Why have you not considered solder? That was probably the way the tank was originally built.
T
Tomterrific
Postby Wolffarmer » Sun Dec 25, 2016 10:00 pm
If that is a wick lamp you should not have much problem sealing it. JB weld is wonderful stuff.
Wolffarmer
Images: 304
