I wonder if setting ply on top of walls and then spars on top of that is even better.
QueticoBill wrote:I could be way off base and it may be a terrible idea, but seemed easy. After seeing halfdome's pictures, I wonder if setting ply on top of walls and then spars on top of that is even better. And then I'm thinking I have a lot of narrow t&g cedar, and wouldn't that make an interesting ceiling. Laminate foam, ply, and final roofing on top of that. But please, dissuade me if you think I'm off base.
QueticoBill wrote:If I were not putting a "frame" on the sides, I'm sure I'd go with the rabbet, but with the frame piece, it's simply a deeper and "off set" rabbet, with deeper seat and equal or thicker edge. I can still pre-finish ceiling.
I need to pull out my grad school structures class notes and see if I can make the stressed skin roof panel work with 1x on the flat. Albeit, loss of insulation. I'm leaning toward 1/4" ply. I'm not even sure if there are published engineering data for 1/8" ply.
QueticoBill wrote:PS: I really appreciate the discussion. I know you are only sharing lessons from your hard earned experiences. Thank you.
