Battery Maintenance
Anything electric, AC or DC
Battery Maintenance
Postby IndyTom » Mon Feb 20, 2017 10:35 pm
Ok I am trying to decide where to put my batteries and I got to thinking about doing maintenance. With normal moderate use (draining less than half way between charges etc.) do I need to check my batteries? If is every day, then I'll have need to change my plan. If it is once a week, or before every weekend trip, then that is ok, I will leave them where I am planning.
Never trust a skinny cook
IndyTom
Images: 42
Re: Battery Maintenance
Postby noseoil » Tue Feb 21, 2017 8:38 am
About as often as you would a car battery, if it's a flooded lead-acid type. I went with the AGM type, since the location I chose makes it a bit more difficult to check on the build.
Access to the battery is a key factor in maintaining the battery to have it last as long as it should & function properly. The harder it is to check, the more likely it will be to fail when you need it most due to simple maintenance issues (cables, fluid levels).
137905
noseoil
Images: 669
Postby Dale M. » Tue Feb 21, 2017 10:10 am
With new batteries there is not much maintenance other than keeping it at proper charge through winter months or long time with not use, a battery maintainer (smart trickle charger) will do the chores, main thing would to take a peek at would be to see that there is no corrosion build up on terminals... Other than that they are pretty much install and just use them...
Dale
Dale M.
Images: 18
Postby tony.latham » Tue Feb 21, 2017 11:44 am
I think you need to also consider your winter maintenance plans. This would be a good time to figure out if you are going to pull it in the winter and keep an eye on it or charge it in place with a maintainer.
My battery stays in my tongue box in the winter with a 20 watt solar panel keeping it a live. When it snows, I brush it clean. Once a week I check the voltage to make sure the system is keeping it alive.
You're a planner, that's a good thing.
Postby IndyTom » Tue Feb 21, 2017 2:12 pm
Thanks for the replies. Yes, I am planning to buy flooded deep cycle batteries, because of cost, and I am seriously considering buying golf cart batteries. The space I am considering is in the cabin, under the bed. I know the space needs to be sealed from the rest of the cabin, and I plan to vent the box through the galley. It sounds like the maintenance schedule is pretty minimal so I am good with going under the bed once a trip or so to check on things.
Thanks everyone.
IndyTom
Images: 42
Postby tony.latham » Tue Feb 21, 2017 2:47 pm
Just wire in a voltage meter and eyeball it after your battery has been at rest for a half hour or so:
https://www.amazon.com/ZJchao-zjchao030 ... B00JUI7VW8
(Just one example)
They pull so little amperage that it won't draw your battery down.
Postby bdosborn » Tue Feb 21, 2017 7:33 pm
I check mine quarterly when the trailer is in storage, monthly if I'm camping a lot.
Images: 776
Postby Shadow Catcher » Thu Feb 23, 2017 8:37 pm
The one thing you need to check above and beyond state of charge in a conventional Lead Acid is water level, mine is AGM so not an issue but it is something you need to do and add distilled water.
Postby IndyTom » Thu Feb 23, 2017 10:02 pm
Shadow Catcher wrote:The one thing you need to check above and beyond state of charge in a conventional Lead Acid is water level, mine is AGM so not an issue but it is something you need to do and add distilled water.
That was actually the question I was trying to ask originally. I am planning to have a volt meter to get a rough idea of state of charge, but was wondering how often I would need to check the water. I think I have a good idea of that now.
IndyTom
Images: 42
Postby lfhoward » Fri Feb 24, 2017 10:33 am
I also would like to know, so subscribing to the thread...
lfhoward
Postby Graniterich » Fri Feb 24, 2017 10:41 am
(Just one example)
My experience was that these due drain down, best to install a switch.
Graniterich
Postby tony.latham » Fri Feb 24, 2017 10:53 am
(Just one example)
I use one of these GT Power meters: https://www.amazon.com/GT-Power-Analyze ... tery+meter
Those devices are great, BTW.
It measures down to .001 of an amperage and will give you a readout of how much power you consume during a trip (amp hours). I can't measure an amperage difference between when it's off or on if I pull the fuse. I believe the drain on a marine battery from these LCD devices (and their LED lights) is inconsequential. But if in doubt, wire a switch.
I can't imagine not having the capabilities of monitoring resting voltage.
Postby bdosborn » Fri Feb 24, 2017 12:07 pm
bdosborn wrote:I check mine quarterly when the trailer is in storage, monthly if I'm camping a lot.
I should have clarified, this is how often I check the water in my DEKA GC batteries. I have a Progressive Dynamics charger and it does a great job of maintaining the batteries without excessive water loss. I check it more often when camping as charging is when the batteries lose the most water.
Images: 776
Postby IndyTom » Sat Feb 25, 2017 1:06 am
Bruce,
I understood what you were saying. I was planning to go with a WFCO converter, and just check the batteries fairly often when charging.
Thanks again for all the input.
IndyTom
Images: 42
Postby bdosborn » Sat Feb 25, 2017 8:47 am
:thumbsup: :thumbsup:
Images: 776
Return to Electrical Secrets
