Causes of castbirin durch ovens to crack.
Postby slowcowboy » Sun Mar 26, 2017 1:05 pm
Lets duscuse when a castirin pot cravks what caouses it...my dad has a idea of the corn bread I cooked thecdoyfh was cold and my Dutch oven half full and it was a change in temputures? Any ideas on causes of cracked cast iron pots let's discuss it here..
Sent from my SAMSUNG-SM-J320A using Tapatalk
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
6000 Club
6000 Club
Images: 166
Re: Causes of castbirin durch ovens to crack.
Postby Woodbutcher » Sun Mar 26, 2017 6:11 pm
I cook my corn bread in a cast iron skillet in the house. Never tried it in a DO. But I always preheat my skillet before pouring in the batter. Never had a problem.
Woodbutcher
Postby S. Heisley » Sun Mar 26, 2017 7:51 pm
Drastic changes of temperatures can cause cast iron to crack; but, maybe there was a small, nearly invisible fissure or a weak spot already in the DO. You may never know the full answer.
Images: 488
Postby slowcowboy » Sat Apr 01, 2017 6:32 pm
I found my problem I pre heated the do on a coleman stove than say it in my do table while I heated my charcoal with cold batter inside yep drastic temp changes I should have had got coals under it before I poured the xirn bread batter into it while the coals heatedvit as I poured into the pan.
slowcowboy
6000 Club
6000 Club
Images: 166
Return to Cast Iron
