If you were to build it all over again ...
If you were to build it all over again, what's your main reason for rebuilding?
I really wanted better quality
29
15%
I really wanted it longer
16
8%
I really wanted it taller
8
4%
I really wanted it wider
41
21%
I really wanted it lighter
33
17%
I really wanted a woodie
6
3%
I really wanted a vintage looking aluminum one
6
3%
I really wanted a more modern looking one
1
1%
I really just want to purchase a factory model
6
3%
Other, I'll add my note below!
51
26%
Total votes : 197
Re: If you were to build it all over again ...
Postby Oldragbaggers » Thu Aug 08, 2013 7:37 pm
My next build, if there ever is one, is probably taking shape somewhere in Elkhart Indiana.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby KennethW » Sun Jul 27, 2014 8:43 am
If I build a 2nd tear, It would be 4x8 on a HD trailer with the axle above the spring. (center leaf removed) The trailer would have the 2nd and 3rd beams installed below the side rails so that the below floor storage floor have a slot to slide into and would be made wide enough to fit the spare tire. :x The 5th and 6th beam would be also below the side rails to lower the galley floor. I would store the cooler on the galley counter. (A cooler always have to be remove to open anyway) And when not cooking the counter is empty(a armless camp chair makes a good cooler stand). I would build it with FRP glued to pink(or blue)foam.(little or no wood). For heat I would use my homemade radiant tube propane heater and for cooling I would build in a swamp cooler pad in the galley wall and use a fantastic fan in the roof to move the air thru the pad. Cooling using very little battery power! :thumbsup:
KennethW
Images: 82
Postby Donutboy » Sun Jul 27, 2014 10:22 am
Oldragbaggers wrote:My next build, if there ever is one, is probably taking shape somewhere in Elkhart Indiana.
I'm inclined to agree with you, but I've seen a couple of gutted out air streams come up for sale locally where the owner started the work and then gave up. This is intriguing...
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby working on it » Sun Jul 27, 2014 11:29 am
My overweight tank of a build 4x8 has almost everything I imagine I'll need for solo camping...however, if ever the occasion occurs where my wife could join me (I started the build for her), then I see the advantages of a 5x10 (if a teardrop/derivative) or even a 6x12 (if a standy). Extra width for dual occupant sleeping space, extra length to fit in all the necessities. I would incorporate somewhat lighter materials, but not where strength counts. If the wife wants a standy, then one with a raisable roof-line. I don't anticipate building either for a while; we travel solo 99% of the time, and we have a 20ft TT standing by, unused, if we do travel together. Actually, I wish to try building a 5x10, just to fit the equipment in better, and to satisfy my need to keep on working on it.
2013 HHRv"squareback/simple" TTT, semi-offroad? 4x8, 2000+ lbs travel weight
  • 3500 lb Dexter axle w/brakes,
  • 27x8.5-14LT all-terrain tires,
  • LED lighting in/out,
  • A/C & heat, Optima AGM battery,
  • extended-run 2500w generator,
  • Coleman dual-fuel stove & lantern,
  • galvanized/stainless steel front rack
[*]147697148599
working on it
Images: 428
Postby glenpinpat » Sun Jul 27, 2014 1:25 pm
I am presently on build #2. My new one will be narrower, off road capable, completely self contained. Trailer will have full size tires and electric brakes with independent suspension. body will be 5 wide instead of 6 wide and will have basement storage. We will also have foam mattress(no more air), prefabed doors, and a pull out fold away kitchen. Our goal is five minute setup including awnings and side tent.
glenpinpat
Postby anntann » Wed Jun 01, 2016 8:19 am
woot! old poll...still relevant!
Our first was 5'x10'. heavy-ish, but towable by a car if you're careful (we use a van). but...fiberglassed wood sides/top. hmmm
2nd tear is ultra light, 42"x8'. easy tow. Trailing arm springs/axle things. easy for offroad. rides like a dream. but again...fiberglassed wood top, painted wood sides. it's...okay. but darnit..
I Want an ALUMINUM early styled tear! :beer:
anntann
Postby Art Mini » Thu Jan 19, 2017 3:37 pm
If I was to build it all over again..........
I would like it:
longer
wider
lighter
better outside finish
larger tires
vintage look
taller
better kitchen
HAVE FUN STORMING THE CASTLE!!!!
Art Mini
Images: 14
Postby Tomterrific » Thu Jan 19, 2017 4:10 pm
I would design more complex. I want a high\low to lessen wind resistance. A lower profile sure would be nice for towing.
It would have a round front with Windows, for style.
Five feet wide instead of four.
Gosh, but I love our little camper just the way she is!
Tomorrow
Tomterrific
Postby VT800C » Fri Apr 14, 2017 1:52 pm
well it's coming along. What would I like? wider (so wife would try it) Insulated (so I don't need to worry about condensation) make sure it doesn't leak (a constant fear) just a lot of little tings. but the main thing is, it's a PROJECT. it will never be finished. I will find some little doohickey to add to it, whether it's a solar powered 'BAR' sign to a porthole window I can try outing in the door to the TV mount to the shelves and pass-through to the backsplash to the....you get my point.
I guess the answer is...want what you have.
VT800C
Postby daveesl77 » Fri Apr 14, 2017 6:13 pm
When I did Conch Fritter's cedar strip siding I decided to take a chance and use just 7 coats of poly instead of going epoxy/poly. I regret that decision. This spring I completely stripped one side and will do the other this coming fall, but still only using spar poly, as I've never done epoxy/FG on a vertical surface. In the meantime, between camp trips, I'm going to try my hand at practice layup of vertical epoxy cloth layup and see how it comes out. If practice works, then I will take down both sides (again) and do it properly.
We are considering building another, but going much bigger while keeping the weight about the same (1,340# loaded). We love Conch Fritter and have no intention of selling, so we'd probably have two if we do build another. Our present one is probably 60%+ foam. If another I'd go for much higher level, like maybe 85%.
dave
daveesl77
Images: 273
Postby Esteban » Fri Apr 14, 2017 8:25 pm
I'm going to start over.
About 10 years ago I started to build a 5 x 10 Grumman II inspired teardrop on a custom built trailer frame. Construction progressed to attaching the side walls and galley bulkhead. Ooops. My home made doors warped probably because I used wood framing with too high a moisture content that I leaned against my workbench for1 to 2 months. Life intervened and my plans stalled, changed, and considerably evolved
I'm going to start over using just the trailer frame, Dexter torsion axle and the 14" wheels I began with. Plus other parts like LED lights, wiring, a PD 4045, plywood and much more that I purchased over the years. I'll tear down the existing walls, bulkhead and floor. The warped doors will be junked too.
For the do-over I'll build a 64" wide by 121" long Benroy(ish) inspired teardrop. It'll have more spacious and functional interior cabin and galley areas. The strongest motivation to build a Benroy, instead of a Grumman II, is to have plenty of flat roof area for a permanently roof mounted 160 watt solar panel so its comfortable to boondock for a week or so at a time. I'm 6'4" tall so the two door cabin area will have enough room for a 60" x 80" queen sized bed. The galley will have room for a Camp Chef Oven on a slide out drawer and a chest style ac/dc fridge freezer on another slide out drawer. An AGM battery stored inside the teardrop will be able to be re-charged by shore power, solar power and/or the tow vehicle's 7-way wire connections.
My Subaru Forester has a 1500 pound towing capacity for a trailer with brakes. I'm using a Dexter #9 torsion axle with brakes. The goal is to build a teardrop that weighs 1200 lbs. or less unloaded. To help keep the weight down it will be skinned on the outside with fiberglassed 1/8" plywood, not aluminum sheets. I'll need to be very weight conscious as its built in order to have enough available towing capacity to load the teardrop with cooking and camping gear, food, water, (adult beverages), bedding, clothing, etc.
:thumbsup: :thinking: I'll start a (re)build thread soon.
Steve - SLO, CA
Esteban
Images: 15
Postby Andrew Herrick » Fri Apr 14, 2017 8:57 pm
Whelp ... after building 9 or so ... I've got a book of things I'd like to (and have) done over!
Here's one not often talked about. I'd pick the best darn tapes I could get my hands on. That's right, tape. I swear by premium tapes now. Use the right tape - VHB, EternaBond, 3M All-Weather, CornerSeal, Tite-Seal Steel-Loc, 3M Scotch Super 33+ - and the build becomes SO MUCH BETTER.
Cheap tapes - and adhesives in general - just waste your time.
I'd also have bought every single Kreg jig I could get my hands on :thumbsup:
A few of my builds:
Andrew Herrick
Postby Ron Dickey » Sun Apr 16, 2017 8:40 am
why there?? and how will it change??
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby Ron Dickey » Sun Apr 16, 2017 8:44 am
Andrew Herrick wrote:Whelp ... after building 9 or so ... I've got a book of things I'd like to (and have) done over!
Where do you use that tape?
Ron Dickey
Images: 701
Postby Andrew Herrick » Wed Apr 19, 2017 12:14 am
- VHB: Just getting started with it. So far, it's the best stuff I've found to attach aluminum siding to plywood without oil canning.
- EternaBond: Seals the bottom edge of all aluminum siding and the backside of riveted lap joints.
- 3M All-Weather: Flashing for window or door rough openings. Most conformable.
- CornerSeal: At the wall-roof edge joints.
- Tite-Seal Steel-Loc: Same as 3M All-Weather. Not as conformable, but sticks better to polystyrene.
- 3M Scotch Super 33+: Electrical tape. Strong adhesive; no residue.
And that's just the start of the list! :)
A few of my builds:
Andrew Herrick
Return to User Polls
