Qool Stream. First time builder
Postby Mudpuppy » Mon Apr 17, 2017 11:33 am
[album][/album]147665
Here is what it looked like in my head
Apologises for the one picture per reply
I have never done this before
I will add more comments later and I have found out you can add more than one picture
(If I do not make mistakes I will never learn anything that is my motto)149986151200
quick cover update showing where i am up to151242
Mudpuppy
Images: 197
Re: Qool Stream. First time builder
Postby Mudpuppy » Mon Apr 17, 2017 11:35 am
147666
Here is the revised version now made longer and a change of window shapes
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:37 am
147668
Sketch of the subframe I will be making this out of timber first as I am better with wood than metal
Mudpuppy
Images: 197
noted all of the sizes to save time later
147669
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:38 am
147670
this was my first frame mock up but the corners did not feel right so i redid them
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:39 am
147671
I bought this old trailer to use the parts for the mock up but mainly for the classic mini wheels it had on it
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:40 am
147672
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:41 am
147673
Mudpuppy
Images: 197
147674
I wanted the wheels to be inset and not set on the outside so had to cut some timber away
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:42 am
147675
whole subframe redone with new corners and centre supports moved around
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:43 am
147676
Timber frame now complete and underneath is the steel box section tubing I had just bought
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:44 am
147677
I have bought some recycled ply to make the floor out of
here cutting to fit
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:45 am
147678
cutting the corners off and its done
Mudpuppy
Images: 197
147679147680
floor now getting 2 coats of ducksback preserver
although both top and bottom being covered with plastic flooring
Mudpuppy
Images: 197
Postby Mudpuppy » Mon Apr 17, 2017 11:47 am
147661
Here is Maizie our tow car A 1966 vw beetle
Mudpuppy
Images: 197
Users browsing this forum: ghcoe and 40 guests
