lrrowe wrote:I have vague recollections of a similar problem when I installed mine several years ago. In my case, I did not have the incoming AC ground line connected to my bus bar. But I think the newer ones, have eliminated this method. I am sure more knowledgeable folks will set us straight.
GuitarPhotog wrote:The fan on mine does not run continuously, just once in a while when it's delivering a lot of power.
The normal mode output to the battery should be 13.2VDC. What does it measure?
BTW, the PD won't output DC to any circuit if there is no battery present. At least my 4 year old 4045 won't.
<Chas>
nitro_mt_racer wrote:GuitarPhotog wrote:The fan on mine does not run continuously, just once in a while when it's delivering a lot of power.
<Chas>
OK, that would make sense that it runs on a thermostat basically. Where are you measuring that 13.2vdc at? Battery is present but maybe just low on voltage enough to trick the converter into thinking it's not present. I've been charging the battery with an external to raise the voltage so the converter may run.
nitro_mt_racer wrote:Battery measured 12.5v prior to starting today. It's a new blem agm from Interstate. Put the charger on and it now checks 13.2v resting but it's dark and I haven't tried testing since. If I check the voltage across the batt + & batt - it'll just show the voltage of the battery. Not sure how that's gonna prove the charger is working.
