1/4 " underlayment ply radius
Postby QueticoBill » Tue Jul 18, 2017 7:37 pm
So searching here failing me again, will I be able to bend ultraply or similar to 30" radius? 27"? 24"? APA says 1/4" bends to 24" dry but I'm skeptical. Outer veneer grain parallel with axis.
Thanks. I will buy a sheet and try it but wondered if there is a chance.
QB
QueticoBill
Images: 22
Re: 1/4 " underlayment ply radius
Postby tony.latham » Tue Jul 18, 2017 9:46 pm
QueticoBill wrote:So searching here failing me again, will I be able to bend ultraply or similar to 30" radius? 27"? 24"? APA says 1/4" bends to 24" dry but I'm skeptical. Outer veneer grain parallel with axis.
I just stuck my head in the shop and tried bending a 36" x 30" piece. I don't think it's possible.
Two layers of 1/8" Baltic birch would be easy. Doing it and avoiding a void would be the challenge.
Postby aggie79 » Wed Jul 19, 2017 7:40 am
I'm with Tony. Bending two sheets of 1/8" is a lot easier than then bending one sheet of 1/4" plywood.
If you want to try bending the 1/4", you may want to try doing so the way Jerry did for his Retro-Kamper build:
http://www.tnttt.com/viewtopic.php?p=612443#p612443
As you can see, Jerry starting the bends using ratchet straps:
I believe he "crept up" on the radius he needed.
Here is a picture of his installed "pre-bent" plywood:
Image[/quote]
To me, the question is why do you need 1/4"? If you use spars, 1/8" is sufficiently strong.
For more on our Silver Beatle teardrop:
Images: 668
Postby tony.latham » Wed Jul 19, 2017 8:02 am
I strongly agree, especially if it is backed by hard foam.
Postby greygoos » Wed Jul 19, 2017 8:22 am
Use material that bend easily. I am finishing up a project where I used FRP from Home depot to make the radius. Yes it is 2 times the cost of plywood and there is added weight but I was done in under an hour, no waterproofing, sanding, filling, etc. I then skinned in aluminum.
greygoos
Postby QueticoBill » Wed Jul 19, 2017 3:01 pm
Thank you all. I'll get the 1/4 inch for floor and walls and play with it. I plan sparless roof so will see if glue and 1/8 makes sense for the one section that is tight radius, and still use 1/4 for the rest. That would only be 2 extra pc. I wish there was some engineering data for 1/8 but non published I can find.
QB
QueticoBill
Images: 22
Postby aggie79 » Wed Jul 19, 2017 8:15 pm
QueticoBill wrote:I wish there was some engineering data for 1/8 but non published I can find.
Search for "3mm Baltic or Russian Birch":
https://www.wolstenholme.com/pdf/Baltic%20Birch%20Plywood%20Specifications.pdf
https://forestplywood.com/infographics/guide-to-baltic-birch-plywood/
http://packardforestproducts.com/products/plywood/imported-plywood/russian-birch/
BTW, the lower section of my hatch has a 12" radius. It was no problem bending the 1/8" / 3mm Russian Birch plywood at that radius.
The lower front corner of my teardrop has a 6" radius. I skinned that in 1/8" ply also, but that tight of a radius took some persuasion and colorful language. :?
Images: 668
Postby QueticoBill » Thu Jul 20, 2017 7:04 am
Thank you. I did mean engineering values like allowable tension and compression values and modulus of elasticity, not the physical characteristics.
Nice work!
QB
QueticoBill
Images: 22
Users browsing this forum: Google [Bot] and 1 guest
