HALLMARK 6X12 CONVERSION
Re: HALLMARK 6X12 CONVERSION
Postby Tommy B » Sun Aug 20, 2017 11:49 am
Don, afternoon.
Been busy. Got the awning installed yesterday. Sadly it did not have any metal weather shield. As I figured for that price. Oh well.
In that process I discovered I do not have the LED channel bracket as you have. Its $10.00 a foot. I need 8-10 for under the fabric only and will order. No sticky tape or plastic clips for me. I will let you know when I am ready for the soldering point, BUT, :D there is a couple more things.
So in that pic, That is where I thought That antenna should go for protection more than anything but will that spot hinder the signal? Would it be better towards the back? IDK and need advice. Now I just read your thread and I don't want people to think I am trying to mimic or keep up with you, but I too thought I may like to do exactly what you did as far as taking it outside but also to store in the house when in the storage mode.
But for now, where to place antenna please and does the connection stay out side like the solar?
Thanks Don, Kathy found her badge.
20170820_124712 (Custom).jpg (120.34 KiB) Viewed 2574 times
Tommy B
Postby flboy » Sun Aug 20, 2017 12:13 pm
Tommy, would be easier to answer via phone. I have the clips for your LEDs also.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Tommy B » Sun Aug 20, 2017 12:51 pm
ring aling!
Tommy B
Postby Tommy B » Sun Aug 20, 2017 4:19 pm
ok snagged these today.
Axess
AXESS TVD1804-24 24” HD TV/DVD combo with External Soundbar Speaker, SD Card, AC/DC Power, HDMI port, Remote Control
Don that is what it is> :)
91hSBIMflRL._SL1500_ (Custom).jpg (96.28 KiB) Viewed 2534 times
61IQrgwbGuL._SL1500_ (Custom).jpg (40.9 KiB) Viewed 2534 times
Tommy B
Postby McDave » Sun Aug 20, 2017 4:34 pm
Details? Where/$$$. McDavey likey! ... :D ...
McDave
McDave
Images: 412
Postby flboy » Sun Aug 20, 2017 4:48 pm
Very nice!
Don (Flboy)
flboy
Images: 378
Postby flboy » Mon Aug 21, 2017 6:22 am
Tommy, did you get the new fabric installed?
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 7:43 am
Mcdave, Total price: $206.99 for both. :D Amazon. Be here tomorrow.
Yes Don the fabric is installed. Looks great but I can tell it will only last that 3 year or so span. Its just not thick like the original even though it is THE Dometic factory replacement. They were thicker 10 years ago for sure. I may have to retorsion the springs. Should have gone 9 turns not 6.5 I think but it works fine. That will be simple 20 min or so.
Working on led lights. Looking for an appropriate mounting channel. There are many. Don't want to mount any other way.
Tommy B
Postby flboy » Mon Aug 21, 2017 7:49 am
Yes, I was lucky, my awning rail apparently has the LED channel built in.
Don (Flboy)
flboy
Images: 378
Postby flboy » Mon Aug 21, 2017 8:44 am
Tommy, did you see this in your search. The lights are only blue, but it appears to come with the channel for $44?
RecPro RV 12' BLUE LED AWNING PARTY LIGHT 12V W/ MOUNTING CHANNEL - BLACK PCB https://www.amazon.com/dp/B00WKPWS5S/re ... MzbW21ARWF
Seems like there are options out there. Here is a channel only with cover for $27.00 for way over 10ft.
LEDwholesalers Aluminum Channel System with Cover, End Caps, and Mounting Clips, for LED Strip Installations, U-Shape, Pack of 5x 1m Segments, 1902-U https://www.amazon.com/dp/B00PJSUZSK/re ... MzbRAV3CQ8
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 9:23 am
Don, This is perfect, thanks.
It will fit max width of 12mm. Do you recall how wide those light are? I have them but at home and still in the box.
Would like to order today.
Now no more Coleman lantern hanging off awning with blinding light. Don't know about the cover, hope it does not dim the effect but if it does I will not use them. Some people liked that you could not see each and every LED light. We shell see.
If you don't know the size I will wait and measure when I get home. They look less than 12mm to me. IDK.
Thanks! :thumbsup:
AMAZON
$26.99
Tommy B
Postby flboy » Mon Aug 21, 2017 9:28 am
I don't know the size off the top. Look at your order from Amazon. The dimensions are in the description I believe .
1 meter is a little over 3ft so you will get about 15 ft with that. Plenty to do the job. :-)
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 10:28 am
10 mm width. Had to look about 5 times but it was there
Cuttable and Linkable
Led strip light can be cut between every 3 leds without damaging the rest strips. And we will provide 2 connectors for free that you can use to link the strip for DIY.
(Strip width: 10mm)
:D
Tommy B
Postby flboy » Mon Aug 21, 2017 10:32 am
10mm. Then you are good to go!
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Mon Aug 21, 2017 12:10 pm
Don, Just getting it all lined up. I don't know the brand or specs of that TV ANTENNA you loaned me but was just looking at alternatives just in case in case.
Free for Life - Never Pay Your Cable or Satellite For Television Again! 1byone Omni-directional RV TV Antenna can pull in all of your local news, sitcom, kids and sports programs in full HD to any digital-ready TVs, VHF/UHF/FM, VHF: 47-230MHz;UHF: 470-862MHz; FM: 88-108MHz AM: 520-1710KMz.
• Sturdy Mount - The compact mount offers superior wind resistance smaller than traditional RV antennas.
Would this work as good, better, or not at all? :thinking:
I will of course wait and see how yours does first. Maybe just fine.
Tommy B
