Ok, here is my story...I am making a "camper" that will set up on a 5x8 utility trailer. Here is where it gets kind of funky for a lot of folks lol, this system will be sections or panels that come apart and lay flat for travel and storage allowing the trailer to be used as needed and then when I camp it all goes together with t nuts and wingbolts. My question is this I want to run two outlets so clearly I will need two outlets, outlet boxes and cover plates. How do I make a plug that will plug into camp supplied power and run power to the two outlets? the only things I will be powering would be my laptop, lights and here is the biggie the a/c, now its not the big dog ac I'm thinking the 3' high ones that vent outside. At the very least if that wouldn't be an option then possibly a couple of fans.
If it matters my walls would be 1/4 outside 1.5'' insulation inbetween and then 1/4" ply for the inside wall. I will be running 1x2 "studs" as well.
thanks gang,
D
