New build, a standrop....Update 11-28-17
Re: New build, a standrop....Update 9-28-17
Postby Johnysteam » Fri Oct 20, 2017 2:02 am
Thats the finest butchery ive seen. Well done :)
Johnysteam
Images: 40
Postby sagebrush » Tue Oct 24, 2017 8:08 am
:thumbsup: You did GOOD!! :thumbsup: Expected nothing less. :thumbsup:
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
Postby Woodbutcher » Tue Oct 24, 2017 11:51 am
Thanks Guys. I tucked it in the barn yesterday for the winter. Maybe I will head south over the winter for a couple weeks, who knows.
Woodbutcher
Postby Kim Armstrong » Thu Oct 26, 2017 8:46 am
Wanted to ask, when you lengthen your frame I am assuming you cut the frame so the rear cross member would fit back in the main rail or am I missing something? Thanks
Kim Armstrong
Postby Woodbutcher » Thu Oct 26, 2017 9:52 am
Kim, I used 2 cross braces as side rail extensions and bought some steel channel to use as the cross braces which I moved anyway to make room for the drop floor. Sorry, but for some reason I did not take pictures of that.
Woodbutcher
Postby Kim Armstrong » Thu Oct 26, 2017 12:35 pm
Woodbutcher wrote:From the top of the frame to to the roof is 68". The new torsion axle when mounted should make the overall height 83" using 14" wheels.
The frame is "WAY" modified. To lengthen it, I took 2 cross members out and bolted them into the side channel and put the rear cross piece back on. This also gives me 2 thicknesses of steel to bolt the axle back on. The steel mart place did not have a channel that would work so I replaced the 2 moved cross pieces with stock steel. Then I added a piece of 2.25 X 2.25 X 3/16th steel Square tube as a tongue extension. I want to get a tongue box up there if possible.
Ok. I wasn't aware the rear cross member would fit inside of another cross member. So how long is your frame ? Thanks
Kim Armstrong
Postby Woodbutcher » Thu Oct 26, 2017 3:43 pm
Kim, I used a cross member not the rear member. The cross members fit inside the side channel rail. So it was very easy to lengthen. Just re drill a few holes and bolt the rear member back on. I think the trailer rectangle part is 9' 6"long.
Woodbutcher
Postby Kim Armstrong » Thu Oct 26, 2017 3:45 pm
Thanks
Kim Armstrong
Postby Woodbutcher » Thu Oct 26, 2017 7:35 pm
Here are a few more pictures. Got the TV installed with an articulating arm bracket. Had to mount it with a sharp angle down so I could see it right. It will also pull out and turn toward the front of the trailer so I can see it from my bench.
New custom made mattress. It is a weird shape and has to be bent in order to slide in. They sewed the hinge under the cover so I won't feel it. This is an inner spring mattress with a foam layer on top.
New old stock 60's era plastic wall tile installed as a back splash...
Woodbutcher
Postby pchast » Thu Oct 26, 2017 7:45 pm
very nice. :thumbsup:
pchast
Images: 97
Postby Kim Armstrong » Fri Oct 27, 2017 4:43 am
:thumbsup: :thumbsup:
Kim Armstrong
Postby KCStudly » Mon Oct 30, 2017 6:32 am
Very nice indeed. The back splash and counter go perfectly together. :thumbsup: :applause:
Postby spacer » Mon Oct 30, 2017 8:05 am
Vurra nice. I like the way you engineered in some extra space there.
spacer
Postby S. Heisley » Mon Oct 30, 2017 10:52 pm
Wow! :o It just keeps gettin' better!
Postby Woodbutcher » Tue Oct 31, 2017 6:57 am
Thanks everyone. Just about finished but winter came! So the final details will be finished in the Spring.
Woodbutcher
