Have you considered poor man's fiberglass?
Sent from my ONEPLUS A3000 using Tapatalk
clamlamp wrote:Have you considered poor man's fiberglass?
paintm4u wrote:Wow your build is very much like mine. I followed the same path you did and I love my trailer, its just a little longer than yours but surprisingly similar in build and shape.
I'll see if I can figure out how to post pics without Photobucket and let you see mine. I built my own frame also.
click pic to enlarge
figured it out....Since the pics were taken I've cut the bottom off those long fenders and added a roof rack, then changed out the center mounted tongue jack for swing away one, just about drug the center mount off. Its a 5x9 box with a tongue box about 16". The frame box size is 5x10 with 15" wheels, I also put passenger radial tires on it and it works alot better than the trailer tires from China that self destruct at highway speeds. Good luck on your build.
Pmf is canvas dipped in wood glue then layed on wood like fiberglass. Primer then use 3 layers of exterior paint. I'm planning on doing that for my TD later.Jeremy757 wrote:clamlamp wrote:Have you considered poor man's fiberglass?
I have not. Will you explain?
Jeremy757 wrote:What did you guys use for your interior ceiling or headliner? I attempted to use a piece of 1/4 luan but it kicked my ass.
Help me please
Users browsing this forum: Google [Bot] and 17 guests
