I'm looking for small and light weight, because I'm pulling it with a Nissan Frontier.
greygoos wrote:Click on the Design Resources at the top of the page. Go to Rescued Library. There are at least 3 designs that might match up with what you are looking for. Here is a diagram of the first one I came across.
jondbar628 wrote:Florida........The rule of thumb is build wider than the height. Length also matters in terms of trailerability, especially for a higher build. You need to keep the preponderance of weight down low in any build. Can you do this as you envision it without footwells or a dropped floor? Dunno, but it will require very close attention to weight distribution, which includes the materials used in the build.....jd.
FloridaWild wrote:jondbar628 wrote:Florida........The rule of thumb is build wider than the height. Length also matters in terms of trailerability, especially for a higher build. You need to keep the preponderance of weight down low in any build. Can you do this as you envision it without footwells or a dropped floor? Dunno, but it will require very close attention to weight distribution, which includes the materials used in the build.....jd.
I'm looking at simplicity. Bed in the rear spanning the width and accommodating a full twin mattress (38 x 74). Galley in front. A small dinette table, that would slide out from the bed frame, when in use and slide back, when not. No bathroom or conventional plumbing. Just a sink in the galley, that would drain out to ground or in a small portable container. Half of the underside of the bed, would be a trunk area, accessed from outside the trailer. Front portion underneath bed would be storage space. Probably storage shelves/cabinets around top of bed area and above galley. Tongue box to accommodate batteries and electrical components. Construction of the trailer would be 1/4" outside skin and 1/8" inner skin, with 1x2 framing and insulation. I'm figuring dry weight at around 1200# and maybe less than that. I could go 10' length. My original thought was a 6x12 build, but I would like to keep it as small as possible and yet still provide enough space for what I need. I'm a hiker, so I can camp minimally, if I need to. I've just been wanting something to get me out camping, more than a few months here in Florida. So, A/c will be installed in a rear window and removed, when I don't need it. Basically, I need a little dog house on wheels, for me and my dog to go weekend camping in.
PaulC wrote:FloridaWild wrote:jondbar628 wrote:Florida........The rule of thumb is build wider than the height. Length also matters in terms of trailerability, especially for a higher build. You need to keep the preponderance of weight down low in any build. Can you do this as you envision it without footwells or a dropped floor? Dunno, but it will require very close attention to weight distribution, which includes the materials used in the build.....jd.
I can only assume that you understand what could possibly happen by having all of your storage at the rear of the trailer. I would be taking a serious look at your tow all weight with that idea.
Cheers
Paul
Users browsing this forum: Google [Bot] and 9 guests
