d-hartman wrote:KA
I orderered a Flexride axle last week from Southwest Wheel .
I got a 2000# with frame outside dimensions of 60" and a hub face
to hub face dimension of 73-1/2 .I bought 2 15" wheels with 0 offset
and have also purchesed two p205-75-r15 tires .
My plan is to hang my walls over the frame and it looks as if I am going to have 3/8" of clearece from the side wall to the torsion arm.and plenty of tire room.
The torsion arm itself is on a spline so one could cheat it in or out by maybe 1/4" on each side without any problems.
My Frame was welded up last night !
MadJack I will try to post some pictures tonight or tomorrow !
Don
The flexride swing arm is 6.06" from the hub face to the inside of the swing arm. So, 60" body + 1.580" for both sides + 12.12" for swing arms = 73.7". 75" minus 73.7" = 1.3" divided by 2 = .65" clearance between the body & the inside of the swing arm.
Andrew - Yes, Redneck shows the dimension (6.2") http://www.redneck-trailer.com/2004/A.htm Also Redneck only lists one minimum dimension of 6", which must be the 1" spindle for 8" to 10" wheels. Note that the minimum and maximum overhang dimensions only relate to the construction of the axle. i.e. physical limitation of the minimum dimension and the unsprung(?) load at the maximum dimension. Therefore, as an example, 62" (hub face to hub face) minus 48" (outside bracket to outside bracket) =14" minus 6.2"x2 = 1.6" divided by 2 = 0.8" clearance on both sides. I brought this up because I've read that a couple of builders have been tripped up. If one brings the side walls or trim down alongside the frame, one can end up with no clearance. In conclusion, I guess that I would say to call for a hub face to hub face dimension at least 14" greater than the width of the trailer regardless of the mounting bracket location
My axle is 74in face-face I still had to cut a notch in my sidewalls for the trailing arm to clear.
Our axles are 70.37" hub to hub and our body is 60". This gets the tires nice and close the side walls with a 14 x 6 wheel. We notch the side wall plywood to clear the trailing arms. We use Flexiride axles, I think they have a shorter hub to trailing arm dimension. Cary
Cary, Flexiride must use shorter spindles. It seems that everyone ordering a Dexter for a 60" frame gets 72" hub to hub and a 1/4" swing arm clearance. I could have made a cutout in my plywood, but since I hadn't cut the steel yet, I just decided to narrow the width by 1/2" to get my clearance.
Seems to be a common story. The #9 Dexter torflex measures 6.2 inches from the hub face to the inside of the swing arm. Unfortunately that measurement isn't included in every company's literature. Daves' for example. One can calculate the wheel offset, tire size and gap to the body, but not realize that the arm may be closer to the frame/body than the tire.
Well that wouldn't be too different then. I think the Flexi is about 6.06" Not a big difference. Cary
Andrew, Didn't you put together a cross section of a teardrop body etc on a flexiride axle? Do you have a link to that picture?
