Went in to work today and got 5 hours extra in for the week. Had to earn some extra, to offset the spend some extra, I've been doing lately.
Got started on the camper about 12:30 and kept at till 5:30. Got slowed down by detail work, and "design as you go" issues. Still got a good amount done. Spent a lot of the time cleaning up the lower rail of the hatch. When I skinned the hatch I really laid on the PL adhesive and staples on that lower rail. It's where the skin was really trying to pull away from the bending force. So there was a lot of oozed out dried adhesive and some misguided staples too. They were either on or in the way of the surface that my weatherstrip has to glue to. I also wanted to stiffen the lower edge of the skin. I was unsure if I was going to do that on the hatch surface, or if I could hide it on the back side but still stay clear of my weather strip channel. Once I had the area clear of stray adhesive and staples I figured a way to get the stiffener hid on the inside. So I got it glued and clamped along the whole bottom edge. I'm happy with how it worked.
Then I decided to try out the galley cabinet doors and their hardware. So I dry fit the hardware on the doors. Then hung the doors in their openings. I knew the doors were not final fit. Now I know just by how much. It's going to take another long session of getting personal with each one of them and the belt sander. So I'll scribe them to their openings now that their hung, take them off, and have at them with the sander again. Not one of my favorite jobs. Plus I'm going to need to bevel the hatch rail that is right above the hinges. It hits the hinges just enough when you try to close the hatch. I'll have to get at that rail with a 45 degree bevel bit in my router to clear that up.
I'm also going to have to add stiffeners to the back side of the doors. These are the doors that wanted to curl up. I've had them stacked flat with a heavy tool box on top of them for weeks. They are a whole lot flatter now, but still need the help of the stiffeners. So some more details to fuss with.
I wanted the galley to look like the bare bones early teardrops. I was shooting for that 1940's ididit myself from some Popular Mechanix magazine plans look.
So I used the big grain fir plywood and today's low buck hardware. The hinges are plastic marine hinges with stainless barrels. Very strong, and work real well for as low buck as they are. The slide bolts serve as travel locks and knobs for the doors.
Taking the day off tomorrow. Hopefully back at it Monday.
- DSCF3832a.jpg (134.45 KiB) Viewed 3027 times
