noseoil wrote:Easiest way to cut crowns is to use a router & a pattern. Just make the pattern you need & then cut the number of rafters needed for the build. Screw the pattern to the raw stock & use a flush-cut bit to make the trim. Bandsaw first to get close to the line, then use the router to make a finished cut.
This is the way I did the hatch ribs. It was about a year+ until it was assembled, but fit well enough when it was time to put it together. Same thing will work for the crowns. Plywood, 1X3, poplar, oak, whatever you need.
You can also make a simple glue jig to laminate the spars, but it takes extra work, clamps & thinner strips of wood for the lamination. They would be plenty strong this way (think miniature glu-lam beams) & would be uniform in section & strength. No need to worry about grain run-out with lamination, as cheaper wood can be used to give a strong beam.
aggie79 wrote:For the OP, a roof camber or crown will work, but only for a "flat" roof. For a teardrop or canned ham, where the roof transitions to the front or rear walls, you won't be able to "bend" sheet goods around the camber/contour. I guess you could "feather out" the camber/crown to "flat" from the center of the roof to the point where the curve begins (PI/PT in surveying terms) but that too would be tricky.
Andrew Herrick wrote:Theoretically, you can compound-bend plywood sheet goods a little ... what's the maximum camber you could use on a teardrop, you think? And more importantly, would it matter? I think a builder could bend a 1/8-inch plywood around a "flat" roof with a 1/4-inch crown ... but would that 1/4-inch crown (roughly 0.10 in/ft slope) be enough to matter for strength and water shedding? That would depend on your roof material, too.
Users browsing this forum: No registered users and 26 guests
