tony.latham wrote:You might consider Vintage's HT09 trim:
https://www.teardroptrailerparts.com/hinges---aluminum-trim.html
lacofdfireman wrote:
Anyone recommend a good caulk to use on the top edge of this FRP? Seems like people say stay away from anything with silicone. Also I need something paintable.
Pro
Pro
BigStretch or OSI. Lowes will have both.
lacofdfireman wrote:redbicycle wrote:Lowe’s recommended this? Do you think it’s fine. Doesn’t say silicone. But does say silicone like.
redbicycle wrote:I used big stretch on some scraps this morning. I'll paint it tonight and give you an example.
. Yes for sure. Great idea.greygoos wrote:May I suggest you caulk the top of the trim only. If water does happen to get in on top and the bottom is sealed then it stays there.
lacofdfireman wrote:redbicycle wrote:I used big stretch on some scraps this morning. I'll paint it tonight and give you an example.
I ended up taking my stuff back and bought “Big Stretch.” Already put it on. It was pretty easy and seems like good solid stuff.
