My First Foamie
Re: My First Foamie
Postby GPW » Fri Apr 12, 2019 4:50 am
Looking Good … 8)
Re: My First Foamie
Postby stharding1836 » Fri Apr 12, 2019 7:27 am
GPW wrote:Looking Good … 8)
Thanks!!
stharding1836
Re: My First Foamie
Postby stharding1836 » Thu Apr 18, 2019 12:59 pm
Got the flooring down and I painted the furniture.
Floor and paint 5.jpg (50.85 KiB) Viewed 2467 times
Floor and paint 4.jpg (61.44 KiB) Viewed 2467 times
floor and paint 3.jpg (63.77 KiB) Viewed 2467 times
stharding1836
Re: My First Foamie
Postby GPW » Fri Apr 19, 2019 7:35 am
Moving right along !!!  8) :thumbsup:
Re: My First Foamie
Postby stharding1836 » Mon Apr 22, 2019 7:44 am
GPW wrote:Moving right along !!! 8) :thumbsup:
Yep, now I need to find a door or figure out how to build one.
stharding1836
Re: My First Foamie
Postby GPW » Tue Apr 23, 2019 5:17 am
You may want to try Foam with wood edges …
Re: My First Foamie
Postby stharding1836 » Tue Apr 23, 2019 9:29 am
GPW wrote:You may want to try Foam with wood edges …
I was thinking of something similar. I think I might try the foam with wooden edges, but also sandwich the foam between two pieces of 1/4 ply with the outer piece having about an inch overlap all the way around. Then just attach some weather stripping to the inside of that for a seal.
stharding1836
Re: My First Foamie
Postby GPW » Wed Apr 24, 2019 5:39 am
That should work , but you don’t need all that plywood , unless you really like it !!! You must build it the way You like to … ;) :thumbsup:
Re: My First Foamie
Postby stharding1836 » Wed Apr 24, 2019 10:37 am
GPW wrote:That should work , but you don’t need all that plywood , unless you really like it !!! You must build it the way You like to … ;) :thumbsup:
How did you go about sealing your door?
stharding1836
Re: My First Foamie
Postby GPW » Thu Apr 25, 2019 5:22 am
..we covered over the foam and wood edges with a heavy Kraft paper , then added the canvas and paint over that … 6 years and counting living outside ... :thumbsup:
Re: My First Foamie
Postby stharding1836 » Mon Apr 29, 2019 10:28 am
GPW wrote:..we covered over the foam and wood edges with a heavy Kraft paper , then added the canvas and paint over that … 6 years and counting living outside ... :thumbsup:
Thanks, that gives me an idea of how mine should look.
stharding1836
Re: My First Foamie
Postby stharding1836 » Mon Apr 29, 2019 12:18 pm
How wide was your door?
stharding1836
Re: My First Foamie
Postby GPW » Tue Apr 30, 2019 5:29 am
I believe it was 30“ wide ...
Re: My First Foamie
Postby stharding1836 » Mon Jun 03, 2019 7:48 am
I've got one wall cut out. It's not glued up yet, I just wanted to see what it looked like.
Wall 1.jpg (53.92 KiB) Viewed 2153 times
stharding1836
Re: My First Foamie
Postby stharding1836 » Fri Jun 07, 2019 7:37 am
I got the windows and the door cut out, and I have one wall glued up.
Walls 2.jpg (56.51 KiB) Viewed 2118 times
Walls 1.jpg (57.7 KiB) Viewed 2118 times
stharding1836
