#4
Re: #4
Postby tony.latham » Thu Apr 25, 2019 8:45 pm
More template work today.
I cut the profile and trued it up using a pint of elbow grease. Speaking of a pint... :beer:
I've got most of the 'drops details drawn in:
It makes for a stronger hatch spar if you butt it along the bulkhead, but I need that space to run wiring. To make up for it, the spar will be laminated oak.
Re: #4
Postby tony.latham » Sun Apr 28, 2019 10:33 pm
I got a few things done...
The template is complete and stashed. Take a look and tell me what's wrong with this :pictures: ...
And the first skeleton core is glued up:
:beer:
Re: #4
Postby Tom&Shelly » Mon Apr 29, 2019 5:59 am
tony.latham wrote:I got a few things done...
You need to give us a virtual tour of your brand new (gravity defying) workshop one of these days.
Tom :thumbsup:
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2025
Re: #4
Postby Atomic77 » Mon Apr 29, 2019 8:02 am
I admire you for starting #4. I thought at one time I would build #2 to perfect all the things I learned from #1. I've since changed my mind. One and done. Nice work Tony.
Sent from my SM-N950U using Tapatalk
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Re: #4
Postby tony.latham » Mon Apr 29, 2019 8:45 am
It's 22 x 28'. Huge with respect to my shop history. Figuring out where to stash the template was a head scratcher but it worked. With all my tools, the new chassis sitting on supports, and my 4 x 8' bench set up with the walls started... it's tight. I need to manage the flow of materials and parts. It'll make a big difference when I can wheel the chassis outside. :thumbsup:
T
Re: #4
Postby tony.latham » Tue Apr 30, 2019 8:39 pm
Today I gang cut the skeletons... (they were screwed together).
That big vertical strip will support the sides of the bulkhead dados and the butt joint of the 1/4" exterior sheet. The heavy horizontal chunk is for drawer slides. The skinny vertical piece is for adhesion surface for the interior/exterior ply.
The lower-left "meat" is for the headboard dados and the 45º is for adhesion of the interior/exterior skins.
But the biggee was cutting the ceiling shelf from the skeletons. With my other builds, I had used a jigsaw. On this one, I used my plunge base and Rockler's router guide so it had my full attention.
I think it took me four passes per skeleton but they are nice and plumb. I'd choose this method again and it was a good warm-up for when I cut the hatch ends.
:beer:
Re: #4
Postby Atomic77 » Tue Apr 30, 2019 8:45 pm
#4 and it shows. You are streamlining your process. Nice work with the plunge router.
Michael
The Astroliner
Atomic77
Images: 309
Re: #4
Postby Tom&Shelly » Wed May 01, 2019 5:50 am
tony.latham wrote:But the biggee was cutting the ceiling shelf from the skeletons. With my other builds, I had used a jigsaw. On this one, I used my plunge base and Rockler's router guide so it had my full attention.
:beer:
Nice! What is the bit diameter?
Tom&Shelly
Images: 2025
Re: #4
Postby tony.latham » Wed May 01, 2019 6:56 am
:beer:
1/4” spiral upcut. The offcuts should be the correct height for the spar blocking now.
T
Re: #4
Postby noseoil » Wed May 01, 2019 7:50 am
Tony, very nice approach to this one. Looks like those "few" previous builds are paying off on the latest. A router really is the "poor man's CNC milling machine" with the ability to do setup work & tooling for so many things. Looking forward to the build & finished results! Will be curious to see the finish with your new coating system.
137905
noseoil
Images: 669
Re: #4
Postby tony.latham » Wed May 01, 2019 8:14 am
Which reminds me, I need to order fiberglass and epoxy today. I'll do the walls on the bench. :frightened:
T
Re: #4
Postby Tomterrific » Wed May 01, 2019 8:14 am
I think I got this tip from Harold Payson. When using resin and fiberglass tape to strengthen a joint, cut the tape on a bias. The fibers of the tape will both be across the joint instead of only one fiber. So obvious yet I never thought of it.
Great job Tony and really fine workmanship. I so admire folks who aren't a hack builder like myself.
Tt
Tomterrific
Re: #4
Postby tony.latham » Wed May 01, 2019 8:24 am
Tomterrific wrote:I think I got this tip from Harold Payson. When using resin and fiberglass tape to strengthen a joint, cut the tape on a bias. The fibers of the tape will both be across the joint instead of only one fiber. So obvious yet I never thought of it.
Tt
There's a great thread on that:
http://www.tnttt.com/viewtopic.php?t=34887&p=633840
I followed that advice on my first build. I'll be able to add a bit more radius to the corners with this build and that should help.
T
Re: #4
Postby swoody126 » Wed May 01, 2019 1:28 pm
DUCKWORKS BBS sells the bias cut fiberglass tape by the yard or by the roll
https://www.duckworks.com/product-p/fib-biax-parent.htm
a BTW, i used2 use West System stuff exclusively but have been using DuckWorks recently w/ excellent service provided
the RAKA Epoxy they sell has a UV inhibitor & a BLUSH resistor in it as well as being considerably le$$ co$tly
and i personally feel it doesn't smell as strong as West System stuff does(butt i only use any of that type of products in WELL VENTILATED AREAS)
i have also started using their WOOD FLOUR as a filler as i'm using up my West fillers and unless i need the glass strand filler i'm thinking i'll stick w/ the flour for filing n fairing
swoody126
Re: #4
Postby tony.latham » Wed May 01, 2019 2:34 pm
swoody126 wrote:DUCKWORKS BBS sells the bias cut fiberglass tape by the yard or by the roll
Thanks on that Duckworks source. I'll probably punch the button.
I've been using Raka for a long time. I don't need their UV resistant stuff but maybe the anti-blush stuff.
Users browsing this forum: No registered users and 25 guests
