kristaology wrote:Here's a quick question for anyone following. I came across a Marine wood sealer called "Seal-Once" on Amazon. Their website boasts this product as waterproof, eco-friendly, penetrating, breathable, with a UV barrier added to it. And its cheaper than epoxy. Here's the thing....its water based?
https://seal-once.com/marine-premium-wood-sealer/
I want to understand waterproofing more in depth. Can anyone give me any advice on this? I know epoxy is a go-to and is highly trusted when it comes to waterproofing the exterior of a tear, but its SO EXPENSIVE! Educate me, please! Why wouldn't something like this work?
I'm not familiar with nano technology, but that seems to be the base on which this company can claim such magic. I'm curious to see if anyone had tried it.tony.latham wrote:kristaology wrote:Here's a quick question for anyone following. I came across a Marine wood sealer called "Seal-Once" on Amazon. Their website boasts this product as waterproof, eco-friendly, penetrating, breathable, with a UV barrier added to it. And its cheaper than epoxy. Here's the thing....its water based?
I’m suspicious as to their claim of it being both waterproof and breathable. How can that be? Liquid Gore-Tex?
Epoxy isn’t cheap but it does a great job of sealing and plasticizing the surface wood fibers. It still needs a UV barrier.
T
I don't think it's intended for making the cabin breathable. The website has details that claim it penetrates the wood like CPES would, but still allows moisture already inside the wood to exit, like the solvent in varnish. Therefore, it should allow the wood to expand and contract as the weather changes. Reviews I have found say it beads water like it should.Aguyfromohio wrote:I don't see how breathability is an advantage for coating a camper. The roof vent and windows let moisture out.
When I think through the exit path a water molecule would travel, it starts in your exhaled breath. Then it diffuses through the cabin air volume to the interior wall. Next it would travel through that interior finish; wick through the wall panel; then out through our fancy breathable waterproof finish. You would need awfully good laboratory equipment to detect the trace amount of water that would move slowly through the wall in that process even over days and weeks.
Fully impervious water barriers for walls and roof seem the best approach. Add ventilation to clear away moisture.
kristaology wrote:I don't think it's intended for making the cabin breathable. The website has details that claim it penetrates the wood like CPES would, but still allows moisture already inside the wood to exit, like the solvent in varnish. Therefore, it should allow the wood to expand and contract as the weather changes. Reviews I have found say it beads water like it should.Aguyfromohio wrote:I don't see how breathability is an advantage for coating a camper. The roof vent and windows let moisture out.
The problem I see with raptor liner and hardening sealants is that they don't expand with the wood and they have the possibility of cracking in hot humid weather, which is all we have here in Missouri.
Sent from my LGL83BL using Tapatalk
Those are great points. I'm an old engineer, and I've learned to give traditional solutions a lot of respect, because a good track record over decades is some of the best evidence we can get.
Fine furniture is often finished with varnish, lacquer, paint or shellac. Wooden boats use the same finishes.
Of course it's always possible something new and better has popped up.
We used "the mix" ( polyurethane varnish diluted with mineral spirits) and so far so good, like many others around here.
You will probably be just fine trying the new stuff. Worst case scenario is not that bad, you can always recoat with something else if the new stuff does not work out.
Do yourself a favor and check that the new stuff does not have a silicone chemistry. If you want to recoat later, silicone may prevent anything else from sticking or soaking in.
The problem I see with ... hardening sealants is that they don't expand with the wood...
kristaology wrote:...
Jeremiah worked on the sliding mechanism for the galley cooler. We went with a rather large 9-day cooler that had some difficulties fitting under the counter height we needed. So to put the sliding channels on the floor with a board on top of those wasn't working.
Jeremiah came up with a neat idea, but he ran into a little more work than I think he was expecting. He cut channels in the 1/2" floor ply to fit the slide bars down into. Then he slid some 3/4" ply pieces underneath the floor to screw the slide bars into, creating a countersunk slide mechanism.
He cut a 1/2" piece of ply for support on top.
We are having a little trouble getting it to slide well, and are worried about it being able to handle the weight of our cooler. The slides are rated for 100lbs, but there is a lot of resistance when it is extended. We may end up putting a support chain from the wall to the slide board to help pull up the slides when they are extended.
Any advice is welcome.
