#7. If using fiberglass instead of PMF, am I correct in that you need to use Epoxy resin if you are using XPS foam, but Polyester Resin is fine with Polyiso foam?
dbhosttexas wrote:Okay probably some dumb questions here, but I am getting confusing info online about this and want to narrow it down for my foamie build...
#1. Recommended foam appears to be XPS (the pink stuff).
Yes! Works real well! I went 1 1/2" yet most go 2".
#2. Recommended adhesive for foam to foam bonding is Gorilla Glue. But which one? Gorilla makes a TON of different glues. I have seen some folks use expanding foam as an adhesive between panels as well. What works well?
I used the standard spray with water . There is a discussion of the tube adhesive that seems to be much easier to use and very strong.
#3. The skin / fabric for the PMF. I have seen TONS of folks here talk about canvas, but I have also seen discussion about using old bed sheets. Which is it? King size sheets are $1.00 a piece at thrift stores near me. Goodwill charges more, but VFW thrift shop has them more often and again, for dirt cheap.
I did bedsheet on the interior. Now that I've skinned my exterior, I see why canvas is used. So much stronger! There is also a thread on another supplier of better canvas than the HF stuff. I would check that out.
#4. Is it Titebond II in a dillution and if so at what ratio, or is it Glidden / PPG Gripper primer, and is it straight up or dilluted and at what ratio? I already have 2 gallons of TBII I got for another application that needs to be used for something now...
The Glidden Gripper is gone now. PPG version is garbage. I used SW Pro-Cryl yet there bonding primer seems nice, just haven't tried yet. TB2 is real good over plywood or bare foam (as I have read). I faired my foam and the TB2 tests didn't work for me. I went primer.
#5. What is an appropriate top coat / paint for the finished product?
Start with water based, end with water based. I'm a SW fan, yet other products would work as well.
#6. Does a foamie need wood reinforcements to support things like door hinges, windows, etc...? I am thinking it does but I haven't tried yet and figured why waste the time, effort and money making mistakes?
I say yes. What and how much is determined by what you want to do. I routed in a few sections of plywood where I thought I would need strength or attachment. Who I saw what it increased, I realized I could have gone much further with my build.
For me, the juries out whether going PMF (correctly) is overall cheaper than PMF..
and is Cheaper if you do it the right way …
tony.latham wrote:and is Cheaper if you do it the right way …
So... what does it cost to PMF a teardrop?
GPW wrote:JMHO :
PMF works and is Cheaper if you do it the right way … Although we LOVE Fiberglass , It's always the temptation to go for a full on shiny finish which is just a lot of work … With PMF it's basically “weave" or nothing …. best thing is you have a CHOICE !!!
As it turns out, although collectively we ( all of us ) in the beginning to encourage participation and creativity , didn’t want to make any RULES , it has evolved over the years , methods that work Better than others … Easier and cheaper too …
The whole point of a Foamie is Cheap and Easy !!! A “hard tent” But with “No Rules” you can make it into ANYTHING YOU want !!!
And just to mention , working for years with Epoxy , we developed a “sensitivity” ( allergy ) to the material that makes us break out in itchy red spots … Not Fun !!
TB2 , GG , water based Paints and primers , all have worked Great for me ( No spots either ) 6 years living outside and counting …
Pmullen503 wrote: The canvas stays flexible over the soft substrate and really is self healing from dents and dings. Epoxy glass is relatively less flexible and if stressed too much will break or delaminate.
That is a great point! I'm finding the PMF (canvas) to be very strong, as others have said I would see as I built and covered. Mine has yet to cure, but very strong in it's current stage of drying. I have a couple SIP samples from another, from another group that is very strong with fiberglass on both sides. The one that has my attention is the gel-coated one. I guess one could gel-coat over PMF, but I don't know for certain..
It's really hard to sand fiberglass flat over a soft substrate unless it's quite thick (which defeats the weight saving benefit of foam.)
So the question becomes are you for $200 only doing the exterior? Also your cost of finishing over should be added.
What is your cost with both these added in?
