at this point thinking screw it go flexiride. only concern I have with them is how does it mount?
damn you Tony...
Wellcraft290 wrote: at this point thinking screw it go flexiride. only concern I have with them is how does it mount? the plate gets welded on but with a 2" frame rail will the arm have enough room to go n the other side of the frame rail. their information kind of blows.
I welded my Flexiride to my 2x3x0.083" frame:
the issue I have seems to be making sure i have room for the wheel and tires.
tony.latham wrote:the issue I have seems to be making sure i have room for the wheel and tires.
I use Dexstar trailer rims without any offset so I probably can't help with whatever offset you have on your rims.
They showed up with 0.75" positive offset
