Pmullen503 wrote:A hot iron over a wet cloth will steam out that writing. So much so that you may not need to use filler.
JazzVinyl wrote:Ripped down pressure treated 2x4's to be the 1x2 floor spacers:
ghcoe wrote:Floor spacers are upside down. The tapper is designed so that it clears the drip edge, but has full support of the trailer frame.
JazzVinyl wrote:George, do you think leaving the last one off would be okay?
Also, George...my spacers are thicker then the 1x2's you specified. Might have to go with a different drip edge (like on your house) to account for thicker spacers. Think that would work? Or should I fall back to the specified 1x2 spacers?
Cheers...
ghcoe wrote:If there is not too much overhang it should be ok. Especially since you are making a box frame for the floor. Which if you put a sheet of foam in you would insulate the floor more. Just a suggestion.
Spacers probably would be fine. My spacers show some as well. I don't really notice since I painted the spacers the same color as the trailer. No biggie.
JazzVinyl wrote:
And I wonder if you could post some closer photos of the drywall item you are using as the drip edge?
Do you "drip edge" front and back, too?
Appreciate!
