Can you take a photo of which direction the winch is facing? Which direction along the wall I guess
Here is where it sits. In this pic, I do not have cables hooked up.BigDave_185 wrote:Can you take a photo of which direction the winch is facing? Which direction along the wall I guess
pchast wrote:May I suggest a jamb nut on the turnbuckle or
at least carter-pin and tape them.
I love this flooring, but the drop gate does get slicker than I care for with wet tires on the Victory Kingpin especially on steeper gate inclines. The dirtbikes aren't so bad with the knobbies and being much lighter.brianjonesphoto wrote:Thanks for all the details Don.
I see you have the vinyl diamond plate tread flooring. Does that get very slick when wet? I know the coin style is easier to clean but pretty slick on the ramp when wet.
Thanks.
McDave, thanks for the feedback on YouTube about the limit switches. Runaway in the up direction could really do some damage. Down, not so much, but still not good and easy to include in circuit. Runaway could happen if the remote sticks or etc..McDave wrote::applause: That a boy!
McDave
McDave wrote:Let's try this again. My earlier post disappeared when I hit submit. IDK.
Yeah, that's what I had in mind. Maybe some sort of "beads" or similar clamped to the cable to trip the switches. I'm not familiar with the winch and remote system, but I'd guess relay(s)and a receiver. Reverse polarity to change direction etc. So if using switch as "monitor" during normal ops should be able to move opposite direction only until cable trigger clears tripped switch. Opens circuit to relay or from relay to motor in that direction. If using as safety switch, either switch would cut power to winch. Then an override circuit would be required to move cable trigger off switch. I hope that made sense.?
Hopefully I didn't just open a can of worms for you. You just made this whole thing look way too easy. Can't have that..... kidding
So, I may have lost track here, did you get the sliders for the TV bed installed? I'll go back and check out what I may have missed.
Are you on "wuhan vacation" now? Looks like you dodged a bullet with some of your recent travels. Timing is everything ...
Take of the Mrs. I'm sure she will be working a lot during this time.
McDave
flboy wrote:I did dodge a bullet... I was in China and through some big cities there in late October/early November just about the time this was unknowingly kicking off there. I was eating all the strange food as I am adventurous that way.
McDave wrote:Not Bat Soup. Tell me you did not eat Bat F***ing Soup! Even I would not eat Bat F***ing Soup, and I do all kinds of stupid crazy stuff. But never Bat Soup. WTF is wrong with people, I mean Bat Soup? What happened to common sense and that voice inside you that says "Don't eat Bats, it's bad for you. MMM kay?" Do I actually have to tell people "Don't eat Bats"? Shaking my head so hard I keep falling down. Bat Soup....
McDave
