Build 4.5 by 8' using trailtop fiberglass Components
Re: Build 4.5 by 8' using trailtop fiberglass Components
Postby saywhatthat » Mon Mar 30, 2020 8:49 pm
You do not mix with paint . One wet layer of paint then blasting media . After it tack one wet layer wet pant to lock.After a bit go over to to remove paint from pores
This is a great to add accents stripes
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby saywhatthat » Sun Apr 26, 2020 5:32 pm
Finished my your a cheap as# bed liner used play sand .A bit of glitter in the clear coat. When we order a bit of axles all but one was 58 wide. it was 57'' and the last one .The pod is 58'' Wide .So will use a poc-light frame .Had to do some cutting out on the sides.1 by 2'' I/8 wall
th 014.jpg (258.07 KiB) Viewed 1631 times
slin 002.jpg (66.66 KiB) Viewed 1639 times
saywhatthat
Images: 135
Postby saywhatthat » Mon Apr 27, 2020 11:36 pm
Rise I say .It can stand on it own. used premade 41% 3 per side and one corner 90 % as they can be placed anywhere with this one wanted higher front inter . But had to have two plains in front not as steep as the first one .even the little kick up in back is a 41% Trailtop components glue and go
rise 001.jpg (69.94 KiB) Viewed 1600 times
rise 002.jpg (56.28 KiB) Viewed 1600 times
rise 007.jpg (51.97 KiB) Viewed 1600 times
saywhatthat
Images: 135
Postby saywhatthat » Tue Jun 02, 2020 9:50 pm
I have had many ask where to get one of these kits .I have a extra full squire top kit with more parts to do a 6x6x10 foot trailer.
The reason I have for this sale is. Now they have a 24'' radius profile can build more teardrop style .
It is down in the for sale part of board index .
Father in law will do a full skeleton frame of your design Very easy to change le look avec. With floor for $350 and cost of flooring with clamshell pop-top add $150
For the buyer of this kit placed on your frame .You will need to just add skins
saywhatthat
Images: 135
Postby saywhatthat » Fri Jul 03, 2020 10:47 pm
tr 004.jpg (200.48 KiB) Viewed 1296 times
tr 002.jpg (108.8 KiB) Viewed 1296 times
Quick easy fire resistant door/hatch .Had one of our trailers burn .Fool put burning camp stove is storage compartment then closed fiberglass/over foam door. So to build a FR door on the cheap and fast. If you did something like this .You would miter the ends of the 1/2'' emt Received some sheet metal cut to sides of opening .Hung . then used 1/2 EDM to make frame then pop- riveted to in side . one stick at a time. May fill in gap with body filler. :NC
tr 001.jpg (115.85 KiB) Viewed 1296 times
saywhatthat
Images: 135
