Ill try this first by explaining and then attach a drawing if my explanation is not enough. I am getting ready to install a 3500# Flexiride torsion half axle set on the trailer frame I am building. I cant really find any instructions or past attempts to look at. My question is about how far out the hub face should be from the side rail of the trailer. If I install as I am thinking, the frame rail will be directly over the torsion arm. It would look like if it really bottomed out the arm would hit the frame. If I line it up such that the torsion arm is all the way clearing, then I have a set of bolt holes that go right into my frame rail. I was not wanting to install sleves in the rail if I can help it. The flexiride web site is not much help. I plan on installing them with the maximum down angle (22.5 degrees I think) so the chances of it bottoming out should be very low. It appears there is enough clearance for the torsion axle to actuate unobstructed.
Any advice would help.
